what do i need to know about tmc roadtest
Discussion in 'TMC' started by fullthrotle, Aug 6, 2008.
  1. fullthrotle
    fullthrotle Bobtail Member
    28
    fixing to start there next month and allthough ive been driving for awhile ive been in single axle day cabs pulling doubles and triples so im concearned about the roadtest in a twinscrew sleeper truck and spread axle trailer,its totaly new to me.do they fail you if you float the gears?if you make a 180degree right turn will they fail you if you take two lanes?is it true that they treat you like dogcrap in the orientation,and talk to you like you are pile of garbage?can you idle while sleeping?i was excited about the phone call when they said i was hired but after some of the things ive seen on here im a litle concearned this is a major change for me and want to make sure im not making a mistake thanks guys for the info
  3. Rawlco
    Rawlco Medium Load Member
    384
    200
    Aug 13, 2006
    Central Maine
    Are you experienced in flatbedding at all? If not and since you want a bit of practice with this equipment I would recommend the full two week orientation. Technically as an experienced person you would probably qualify for the one week quick orientation, but the two week will give you several hours of backing practice, several hours of road practice, and several days of load securement training, followed by 2 to 4 weeks out with a trainer. After the time with a trainer you will have your final road test.
    If you are really experienced in flatbedding it is possible to attend the one week orientation, take the road test, and then get assigned a truck, but that does not sound like you.
    They only care that you don't grind them. It is a 13 speed transmission, so almost everybody experienced or not needs some practice with it.
    A 180 degree turn is a U-turn. I think you mean 90 degree right turn. For the road test they want you to keep in the right lane of the road you are leaving, and take as much room as necessary on the road you are entering to miss the curb.
    And they don't fail you, they will mark off points for every error. You can make three or four minor mistakes and still pass as long as you were safe.
    No, but you do need to prove yourself to them. If you are a goof-off you will not get any respect from the instructors. They want you to at least pretend to pay attention. They have a lot of things to cover and they dont' always take the time to hold your hand and ask you if your feelings are getting hurt.
    The amount of fuel you use while idling will decrease your fuel economy. Fuel economy directly affects the points towards higher pay levels. So most of us idle as little as possible. My trainer idled all the time without any problem, except his fuel economy was very low.
    It is a change. This isn't a simple or easy job. Look at it this way: The orientation is the way it is to weed out the people who aren't going to be able to handle the job. They want you to pay attention in class, on the road, and at shippers. Being inattentive around a forklift that is loading you can result in heavy things being dropped on you. Shippers, consignees, and other drivers are going to treat you like dirt and TMC checks to see if that causes you to lose your temper and perhaps lose a shipper or pull out your Uzi and kill a few people. They also measure weather you can wait doing nothing without getting mad, because they don't want people screaming at their Fleet Managers or abandoning trucks when they have to wait somewhere. If you don't want to put up with the orientation then you don't want to put up with this job, plain and simple. I would rather have it this way instead of a company that sugar coats everything until you are in your own truck and then you have a reality check. When you attend orientation you will see some of the things complained about on here, but it isn't nearly as bad as some people claim. Good luck.
    NCBill Thanks this.
  4. fullthrotle
    28
    i did tell my recruiter i was thinking about doing the two week orientation and he insisted i would be better off doing the one week.i think once i get there i will talk to someone there and ask about doing the full two weeks,i think it would put me in a more comfortable place personaly.you are right i was refering to the 90 degree turn,my mistake.not to concearned about waiting somewhere just would call dispatch and tell them im delayed just so they know and keep them informed incase they need that info for reload or something,besides im sure there is paperwork or something i could do.i only want to do the best job i can for whoever i work for so maybe i over think sometimes and like i said ive been driving for 15 years but this is still something new to me and want to make it work.i remember tmc trucks as a kid and i cant believe i may get to drive one.in all my years as a truck driver ive never gotten to drive such equipment,ive always been in woreout,washed up old junky freight trucks thank you for the help. one more question,i need to make around 50 thousand year to make it worth leaving my current job it seems pretty much everyone ive seen makes around that does this seem right,and possible to do staying in linehaul?thanks again sir
  5. Rawlco
    384
    200
    Aug 13, 2006
    Central Maine
    I didn't make quite that much in my first year at TMC, but I also had trouble getting in and out of Maine for a good rate. I ended up bouncing home empty frequently on Fridays and getting loaded on Mondays. If you live in a more freight rich area you should make more no problem. Also when I wanted to be home again within 2 weeks I sometimes had to choose lower paying loads to keep me on the eastern side of the big river. You should be able to make what you want, but sometimes you will have to choose between money and home.
  6. fullthrotle
    28
    thanks rawlco.not sure how the rates are in my area but i do see a ton of tmc trucks around here all the time iknow that doesnt mean much as far as pay but at least i live in a lane that they run quite frequently so i should get home easy.recruiter said home 48 or more weekends easy.where i work there is a fence company around the corner and i see tmc there alot picking up what honestly looks like a pain in the ### load,stacked to the moon with every size and shape piece of freight there is,man ive seen guys in there for three hours straping and tarping that stuff,even in a monsoon rainstorm
  7. bigpapa7272
    bigpapa7272 Light Load Member
    224
    35
    Sep 9, 2007
    Baltimore
    hey rawlco
    tmc is on the top of my list, how is the freight down in baltimore?? Whats better long haul or regional?? Mileage or percentage pay? Ive got 6 weeks of school left and trying to make a decision on where i want to go for my first truck driving job. Any info on tmc that you can enlighten me with is appreciated
  8. Rawlco
    384
    200
    Aug 13, 2006
    Central Maine
    Freight should be decent in and around Baltimore. I crossed baltimore many times, usually once a week, so it shouldn't be a problem to get home. You will probably get good at securing steel coils from the steel mill on sparrows point. I was always slow at it because I didn't do it often enough and would have to think about it, but with practice that can be a quick load.
    I liked long haul. With the regional line haul you have more loading and unloading to do, and you will stay on the I-95 corridor quite a bit which would drive me nuts. You would get home quite easily on line haul, perhaps even once during the week sometimes if you have a great fleet manager. You can always choose line haul and stay out for a weekend to get a long run if you want to get away from the east coast traffic for a while.
    I did very well on percentage. There was some time last winter that I would have done better on mileage, but not enough better that I wanted to switch, and then I had a few good weeks where I made quite a bit more on percentage. Especially in your area you are going to find a lot of short 200 to 300 mile runs that will pay you as much on percentage as you would make on a twice as long mileage run. You could easily spend your week going from Baltimore to Connecticut to New Jersey, to Virginia, then Ohio before going back home. The only run there with any miles on it is to Ohio and back, the rest you would need to be on percentage to earn anything. I also one day had a load out of PA that paid ME in my paycheck $168 for only 90 miles, you can't beat that on mileage.
    Well I can't think of anything about TMC that I have not posted somewhere in this TMC section. If you have any more questions feel free to ask. Good luck.
  9. Rob332
    Rob332 Bobtail Member
    17
    Jun 1, 2008
    Lexington, Kentucky
    Rawlco,
    I have heard there is a good seafood buffet as you come into Maine do you anything about this location? I want to head up to Maine my wife and get some Maine Lobster. Any recommendations for that area?
    Rob
  10. Rawlco
    384
    200
    Aug 13, 2006
    Central Maine
    There are a lot of tourist trap seafood places down on the coast where I 95 enters the state, but I live quite a bit north of there so I can't tell you much.
    For good seafood I recommend the Weathervane chain. They have them all over ME, NH, and VT. I think they have a website. The one in Yarmouth ME at exit 17 on I 295 is one you can get a truck into during OFF PEAK hours. At noon or 5pm the parking lot is full though. There is also a Weathervane in Waterville ME where you can park at the former WalMart behind it.
  11. heavyhaul
    heavyhaul Bobtail Member
    16
    Oct 18, 2008
    Woodland, Ca
    Does TMC have much freight in or out of California? I have been running flatbed and heavy haul equipment for the last 14 years here in California, but i'm interested in getting my own rig and leasing on with TMC. Any info would be great.
