What do I unplug to stop the rev limiter in 9th gear?
Discussion in 'Ask An Owner Operator' started by scoobertdoo, Dec 5, 2021.
  1. scoobertdoo
    scoobertdoo Road Train Member
    1,512
    2,603
    Nov 11, 2020
    Hate my 1500rpm governor in 9th gear. I figure if the truck doesn't know what gear it is in, it will not limit the rpm. Maybe something to unplug so it doesn't know it's in high range? I have an Eaton 10 in a 2016 paccar powered pete
    Don't want to have my truck reprogrammed.
  3. LoneRanger
    LoneRanger Road Train Member
    3,681
    9,564
    Jun 3, 2018
    Programming is the only way that I can think of. Nothing mechanical would be on a transmission to act as a rev limiter.
    Bean Jr. Thanks this.
  4. Pamela1990
    Pamela1990 Road Train Member
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    Are you sure there isn't just a problem that needs to be fixed.
    Seems odd that they intentionally limit rpm to 1500 in 9th.
  5. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    I have an old Corp owned truck. 9th was capped at 1500 and top speed was 65. Got rid of the speed limit, but missed that there was a limit in 9th. Every other gear revs fine, even 10th revs to the moon.
    Pamela1990 Thanks this.
  6. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    The truck must know it's in 9th gear?
  7. Pamela1990
    1,820
    10,719
    Nov 7, 2021
    B.C. Canada
    Thanks for the education, never heard of that before.
  8. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    Makes two of us. I wasn't even aware a manual truck reported the gear to the engine. Welcome to EPA 2017 trucks I guess.
    77fib77 and Pamela1990 Thank this.
  9. Old Man
    Old Man Road Train Member
    4,597
    13,470
    Apr 3, 2009
    Oklahoma City, OK
    It doesn’t have to be reprogrammed, just let a dealer reset some parameters, get a print out of how everything is set. You will be surprised at all they can set to control things.
  10. scoobertdoo
    1,512
    2,603
    Nov 11, 2020
    As I understand it, they have to reprogram the ECU, and if they do I have my own program in there that would be erased. My guy quoted me $300 for the job, but really it's not worth $300.
  11. AModelCat
    161,206
    If its a manual transmission, there is nothing mechanical on that transmission that registers the selected gear, with the exception of the backup light switch.
    Only thing I can think of is maybe the computer is programmed with tire size and the transmission/rear end ratios and it can calculate the gear based on engine RPM and speed? I don't know, never dug into the parameters on a Paccar.
