What do ya'll think about buying a another truck right now?
Discussion in 'Ask An Owner Operator' started by joseph1853, Mar 23, 2024.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    My 2016 Cascadia's getting up there in the miles. She has around 815,000 on her currently. Been noticing the price of trucks has gone down dramatically to where I can get a 2019 model with 480,000 miles for around the same price I paid for my truck around 2.5 years ago. My truck runs fine currently and I have dreams of not having a huge truck payment every month but I'm aware that the repairs on one could average out to be equal to a monthly truck payment either way so I don't know. In another words you could be paying a monthly payment for a nicer newer truck or paying for the equivalent in repairs on a older one in theory. With the truck the way it is now I could probably sale it and get a decent amount to put towards a new truck. Just throwing this out there.
  3. snowwy
    snowwy Road Train Member
    20,553
    13,281
    Jul 6, 2009
    Repairs are more then truck payments.
    But depends on if you run a logging device or not. Repairs could be more frequent.
    And where to buy. I'm noticing prices everywhere for the same model and miles.
    You can find lower miles for the same year. Look for the bang for the buck. I wouldn't pay $50g for a truck with 500k if there's a same truck with 400k.
    But then. I also wouldn't pay $100g + for a 20 or 30 year old truck when I can buy a 3 year old truck. Add a wet kit and be in the same price. With 1/10 the miles.
    It might just be cheaper to rebuild the motor. You already know what you got.
    joseph1853 Thanks this.
  4. Ridgeline
    22,394
    116,374
    What does your OA say?
    Had a dyno done lately?
  5. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Whats OA?
    Haven't done a dyno ever. It pulls fine though. It's also quite and doesn't burn any oil.
  6. Siinman
    Siinman Road Train Member
    5,284
    13,369
    Mar 5, 2017
    Kansas City, MO.
    Think this year will be the worst yet since the down turn. If you can make it I would have no problem getting a newer truck with the prices now.
  7. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Yeah thats the question. If I can make it. That's a big if considering how things have been this last year. What truck would you recomend? Another cascadia with the dd15 or a pete/kenworth with a isx or paccard engine? I didn't mention it my current truck is a 10 speed which I'm thinking probably won't be available with the newer trucks at least not for the most part.
    Siinman Thanks this.
  8. Lyle H
    Lyle H Road Train Member
    1,291
    2,937
    Apr 16, 2014
    Oil analysis.
    Or your “Original Angel” if you watched the Netflix series.
  9. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Oh, right. I haven't run one recently. I used to do them every oil change but they always came back oil fine can run it a bit longer. I ran conventional oil at that time. Now I run full synthetic and it's even better on the report.
  10. Arctic_fox
    4,072
    21,130
    Sep 16, 2016
    Avoid the paccars, the expensive emissions repairs start at around 500k unless you can get one with full and recent paperwork showing the def system was just overhauled esentially. The motors are good the stuff attached to them....less so. The rest is dealers choice.
    Also its good to have a dyno run at least once every 6 months to a year. Its not THAT expensive. If everything comes back clean and good just run it. Tbh a good platinium or whatever the detroit equivlent is could get you another 500k miles easy.
    Biggest worrys would be transmission, wireing harness, diffs and emissions system. Will still be a good bit cheaper then the payments on new. Personally id have an OA done on the diffs and transmission and if they come back good then have the steering rack rebuilt, have all the brakes redone, a rebuild, a new clutch and flywheel, maybe a new 5th wheel plate if yours is badly worn and the def system dropped and cleaned.
    Do that and a lot of them cascadias are known to hit 1.5-2 million before the repairs get out of control.
    That said newer is also viable and woth prices going way down has strong hard arguments as being smarter. But keep in mind a LOT and i do mean A LOT of used trucks on the market right now are going to be from failed O/Os or megas who stopped doing maintaince beyond absolutely nessesary repairs before they traded them in. Or did none at all before the truck got taken back. And its going to get worse going into the downturn. So there IS a good chance you will be buying someone elses issue.
    if you keep your paid off truck and dump 40-70k into refreshing it depending on how deep into the rabbit hole you wanna go. By the time rates come back up and your truck hits critical you should have enough saved up to buy new outright.
    But thats just MY opinion
    KDHCryo, JolliRoger, Siinman and 2 others Thank this.
  11. KDHCryo
    KDHCryo Medium Load Member
    424
    558
    Sep 14, 2023
    Pete's and KW's come with a higher sticker and substandard motors.
    Detroit is a better powertrain option. I'm not including DD15's. Don't get one of those. Get a DD13 at 450 HP.
    Get a 2020 DD13 Cascadia 126 with 400 or 450 HP and a DT12. Adapt it to suit your needs.
    Probably about 65K out the door for a full sleeper truck.
    Doggett Freightliner has plenty of used Maverick freightliners available with a lot of the bells and whistles still under factory warranty on the driveline.
