What do you get for your money
Discussion in 'Kenworth Forum' started by Brdhntr, Apr 23, 2016.
  1. Brdhntr
    Brdhntr Bobtail Member
    14
    6
    Aug 8, 2015
    Minnesota
    I'm looking at pre 2007 trucks and as I search the only ones in good shape are the long hood Petes and KWs. What do you get with these trucks other than an image and ####ty turning radius.
    I'm looking for as reliable and affordable non Def truck as I can find but I'm wondering if the premium price brings any real world value.
  3. brsims
    brsims Road Train Member
    5,296
    6,521
    Aug 8, 2009
    Meadville, PA
    Higher resale value. As a business person, you MUST keep an eagle eye not only on expenses but on something called ROI, or return on investment. Equipment is an investment, and one of the considerations you have to keep in mind is the ongoing value of said equipment.
    For example, a new O/O may look at an older Freightliner Columbia as a "starter" truck to get the business off the ground. Once he develops a reseanable net profit, he may look into an equipment upgrade (a newer truck, perhaps a Pete or KW). Now he has two trucks and will often look into offloading the extra rig. While he has earned profit from using the older truck, he will most likely take a loss on the sale of the older rig simply because old Freightliner Columbias do not hold value. They are cheap trucks, and common as dirt.
    On the other hand, same O/O in the same situation who started with a higher end Pete or KW prior to upgrading will either take a smaller loss on the sale or even sometimes see a profit, depending upon model, condition, and buyer's desire for the truck.
    It all comes down to your business plan and starting capital. If it was me, AND I had the capital, I would look into the highest quality truck I could get my hands on with the best resale value. Every aspect of your business needs to be considered on a cost vs. benefit (or profit) basis.
  4. truckthatpassesyouby
    truckthatpassesyouby Road Train Member
    1,876
    6,124
    Jun 3, 2015
    Every time I see them online with their high mileages all I can think off is that they're overpriced - rebuilt - and that they will need a lot of TLC. I like those trucks but I don't know crap about how to fix one myself so I'm not going to invest in equipment that needs babying. Newbies like me will be better off with something between 380k-680k original miles on the odometer. But anyways, I've seen 2008/9 peterbuilts with c15's that have mileage in the 6/700's for as low as $70k. Maybe the real world value would come from how well you take care of it and how much profit it brings you while still looking like a Boss!
  5. Brdhntr
    14
    6
    Aug 8, 2015
    Minnesota
    I understand the resale concept but I'm most curious if there is an actually reliability advantage. Do these trucks have better materials used in producing them? Are the more easily maintained? Better corrosion resistance? Better components? More durable? I'm trying to avoid throw away trucks.
    truckthatpassesyouby Thanks this.
  6. Mudguppy
    Mudguppy Degenerate Immoralist
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    The reason for the emboldened above is simply that those are the first years of the whole DPF/ emissions crap, and are known as some of the worst years EVER for hoods. I used to drive an '08 and the #### thing was in the shop almost monthly.
    OTOH, anything older, and not only pre-emissions crap, but also less computerized the older you go. So not only easier for somewhat mechanically-inclined to work on, but those older engines were as close to bomb proof as one could get, IMHO.
    YMMV.
  7. Mudguppy
    1,657
    4,064
    Apr 28, 2014
    Wooley Swamp
    FWIW, I'm currently in a '98 KW W900, and she's still able to burn the mile posts, with over 1.5 mil on the odometer.....
  8. haulhand
    haulhand Road Train Member
    Don't just walk away from an 08-09 with a C15 in it run as fast as you can. Those motors have broken more than one fleet owner. The SDP cats were absolute pieces of ####.
  9. truckthatpassesyouby
    1,876
    6,124
    Jun 3, 2015
  10. truckthatpassesyouby
    1,876
    6,124
    Jun 3, 2015
    """"Do these trucks have better materials used in producing them?
    Better components?
    More durable? """
    Did some quick research:
    Yes, corrosion resistant cab made from aircraft grade aluminum alloy with fiberglass roof.
    Electrical wiring, plumbing, and hoses are installed in areas of the frame and around the engine to avoid corrosion, heat, and abrasions.
    You've got aluminum cross members and gussets, easy add-ins.
    The power distribution box is made simpler for you to work on.
    Left hand side battery cradle for "maximum start voltage"
    Huckbolts, torque hose clamps, stainless steel piano hinges on the bulkhead doors, all to keep it from rattling like a plastic modern truck.
    I'd say yes, this truck was, is built to last for many years.
    Last but not least, the thing a lot of people on this site mention is that working on a truck with these hoods allows them to get into the engine better to work on it.
    Cons: heavier frame, more winddrag under cab.
    Pros: better insulated cab, bolts on pannels for easier repair access.
    Now let's wait for W900 owners for real life input!
    AModelCat Thanks this.
  11. strollinruss
    strollinruss Road Train Member
    1,366
    1,699
    Jun 5, 2012
    Montgomery, TX
    Go buy an old international with a N14. You can get one for about 15 to 20k. I drive mine all the time while my 'show' truck sits in the barn. Since you're going older get one pre 99 so you can run paper logs.
    Brdhntr Thanks this.
