What do you know about NEXIQ usb link 125032
Discussion in 'Trucks [ Eighteen Wheelers ]' started by edisonjay, Nov 18, 2011.
  1. edisonjay
    edisonjay Bobtail Member
    16
    Hello.Need you help,thank you,.
    My company needs a tool to do diagnosis especially commins and dodge trucks.
    I find one called nexiq 125032 interface,but i am not sure if it is good.
    Because I know less about it,I just know one called Cummins INSITE 7.5.
    So what do you know about it?
    Compared with Cummins INSITE 7.5,it is a little more expensive than INSITE 7.5,if it is better in function?
    Thanks.Any suggestion will be accepted.:biggrin_25520:
  3. Dino1968
    Dino1968 Light Load Member
    That piece there is what's called a translator, it plugs into the 6 or 9 pin socket on your truck. You will also need a compatible laptop, I have Windows XP for mine, and also Cummins Insite to complete the system. You will have to load the software from the Nexiq product onto the computer,than sync it to the translator. When properly loaded, you start insite, plug in the translater to the your socket and Insite will do the rest for you.
  4. Heavyd
    Heavyd Road Train Member
    7,762
    6,201
    Feb 4, 2009
    Yes, we use these, they work great. Like Dino said, these boxes are just one part of it. You still need a laptop and Insite is the software that runs on the laptop. The Nexiq Usblink allows for communication between the laptop and truck. So you need both. Big $$$ to get into this.
