what do you think of this owner operator job ?
Discussion in 'Ask An Owner Operator' started by Kenworthallday, Jul 9, 2025.
  1. Kenworthallday
    Kenworthallday Bobtail Member
    6
    Hi i found this company is looking for owner operators on indeed, teenstreet. I see they offer really good conditions:
    • 87% of the Gross for you
    • Avarage rate per mile is 3.2
    • Full Transparency - all rate cons will be sent to you
    • Direct shippers, good broker relationships
    • Perfect safety score
    • ELD Compliant
    • No Forced Dispatch
    • Weekly Pay - direct deposit
  3. kemosabi49
    10,901
    47,292
    Jan 13, 2013
    SW Arkansas
    Where is this company located?
    Kenworthallday Thanks this.
  4. NorthEastTrucker
    NorthEastTrucker Heavy Load Member
    971
    1,820
    Sep 21, 2019
    Not bad if they keep their word regarding the transparency with the rate con.
  5. Ridgeline
    22,609
    120,130
    Just fyi, no carrier you are leased to can force dispatch you.
  6. Kenworthallday
    6
    thanks I think i will start the application sounds good. The company is based in Winchester KY.
  7. Kenworthallday
    6
    Winchester KY
  8. dosgatos
    dosgatos Medium Load Member
    581
    1,267
    Sep 18, 2012
    When I got my truck I leased to the same company where I was a company driver. They called it "unforced dispatch". The would offer one load and you didn't have to take it. Then you would sit for a couple of days until they offered the next (one) load.
  9. Kenworthallday
    6
    Probably i will see when i get the rate con i will share it
    Reason for edit: Fixed quote
  10. JonJon78
    JonJon78 Road Train Member
    7,207
    42,209
    Jul 1, 2018
    Can't find any company in Winchester by that name. Do you have a DOT # for them?
  11. Cdemars316
    Cdemars316 Heavy Load Member
    822
    4,974
    Nov 10, 2018
    The only transport usa in KY on safer.fmcsa.dot.gov is out of Lexington and has horrendous safety scores, they also only have two trucks listed so I doubt that they have any contract freight
