i am thinking I need to replace my clutch in a 2000 fld 120 with a 10 speed auto shift. when I try to accelerate to quickly it want to start slipping. Also can I call frieghtliner with the vin# and will they be able to tell me the part# I need?
what does it cost to replace a clutch!!!
Discussion in 'Freightliner Forum' started by richhawn, Jan 27, 2013.
Page 1 of 3
replaced mine a couple of years ago in a pete 379 and all the quotes i got were in the $2600-$3000 range....ended up buying heavy duty clutch, bearings, and clutch brake for about $800 and had a mech/friend do it for $500.....so i got off pretty cheapRideandrepair, NavigatorWife and richhawn Thank this.
I had mine done at Freightliner about 3 months ago, 10 speed autoshift in a Century, cost $2450 for the big clutch. I think it was 1650 ft lb. There were two options I got the bigger of the two whatever it was. If there going to be in there let them check the rear seal out. Well worth doing if you are there already!!!!!
RoadRanger^^ and richhawn Thank this. -
those are not bad prices for a auto, from what I have been told.
i change my clutch in a shop in miami with tax $1452,was a heavy spicer clutch(COLUMBIA WITH AUTO)
richhawn Thanks this. -
We have local mechanics who do it for around 400 labor, clutch, about 500, bearing,seal, turning flywheel, another 150. this is for regular transmission, not auto-shift.1 day job.last time I had one installed, 1100 bucks. I cannot afford to have a dealership do my repairs.
Be sure to get the flywheel turned.richhawn Thanks this. -
10 hours r/r.... Plus parts around 500-750 depending on what you want
i replaced mine little over a year ago in my vnl ,this shop put big clutch, turned flywheel, new rear end crankshaft seal, new forks , new clutch break, new push bearing,so pretty much everything betwen transmission housing and engine is brend new..... i paid with labor 1650$$$ i left my truck on friday afternoon and was ready sat morning
back street slider Thanks this. -
Hey where would your local mechanics for clutch rr be?? Thanks!
I would search for a strictly drivetrain shop.
Page 1 of 3
