What does the "red service ligth" mean when lit, 2001,379 18 speed Auto-Shift
Discussion in 'Peterbilt Forum' started by Mr. Cob, Dec 27, 2023.
  1. Mr. Cob
    Mr. Cob Light Load Member
    Howdy All,
    I have owned this truck for 6 years, driven it 80,000 miles and have NEVER had any problems with the Eaton-Fuller 18 speed Auto-Shift. Today getting ready to head south for the winter, go to start the truck, the shifter is in NEURAL but no "N" lights up in the shift tower or on the dash, what does light up is a red service light.
    I pulled the battery cover, cleaned all the cable ends, covered them in dialectic grease, tightened the hold down nuts. Still no start, no crank over, no neural light in the shift tower or the dash, red service light is still lit on the shift tower.
    Like I said this has never happened before, does anyone have any suggestions of what to look at or things to check? Thanks for any help you can offer, we planned to leave tomorrow morning.
    Dave
    austinmike Thanks this.
  3. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    846
    1,641
    Dec 15, 2021
    Are your batteries all good?Try to jump it with something if you can.
  4. Mr. Cob
    Howdy North Pole Nightmare,
    Batteries are good and fully charged, I have the truck plugged into shore power when it's not being used, it has an inverter/charger that keeps the batteries up. I just had it running a couple of days ago so whatever it is it just happened. Thanks for your suggestion.
    Dave
    North Pole Nightmare Thanks this.
  5. North Pole Nightmare
    846
    1,641
    Dec 15, 2021
    The only other thing I would try is turn the master switch off a few minutes,see if it reset's.
  6. Mr. Cob
    Thanks, I am going to disconnect the ground cable for a few minuets and see if that helps.
  7. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    You have a trans fault. Need to hook up service ranger to obtain trans faults. Cycling ignition off to on a few times rapid may give flash codes thru service light in PD mode. Even when you get the code will still need to troubleshoot.
    Service and troubleshooting info is available at-
    https://www.eaton.com/us/en-us/markets/vehicles/roadranger.html
  8. Mr. Cob
    Howdy Goodysnap,
    Thanks for your reply and the link, I was really hoping this would something simple like bad battery connections but I fear it may cost a ton of money and be a lot of shop time. Just glad it happened in my driveway and not half way to Arizona.
    Dave
