What does this mean
Discussion in 'Ask An Owner Operator' started by Supremexpress, Aug 23, 2017.
  1. Supremexpress
    Supremexpress Bobtail Member
    4
    My solid engine light came on yesterday and stayed on and now I'm having this code engine 0 display on mileage screen and a blanking code 545 25 can some tell me what does this mean
  3. Oscar the KW
    Oscar the KW Going Tarpless
    12,247
    28,120
    May 19, 2011
    Might help if you tell us what truck/engine you have.
    Supremexpress and BigBob410 Thank this.
  4. wore out
    wore out Numbered Classic
    17,158
    211,661
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Means its broke driver, needs attention
  5. Supremexpress
    4
    2014 freightliner cascadia Cummins
  6. Supremexpress
    4
  7. Supremexpress
    4
  8. Just passing by
    Just passing by Road Train Member
    1,176
    3,140
    Feb 25, 2017
    Solid engine light = stop, get roadside assistance.
    There.
  9. Oscar the KW
    12,247
    28,120
    May 19, 2011
    Found this on the web with a quick google search.
    The EEC 61 can be your fule filters plugged or the DEF tank is empty. Most likely it thinks the DEF tank is empty because you have the 545 25 codes which is the sensor for the level valve in the tank itself. This will also cause you to have the issue wit hteh dpf system when that level sensor is faulting.
    Bigrayon, baha and Supremexpress Thank this.
  10. 201
    201 Road Train Member
    12,721
    26,162
    Apr 16, 2014
    high plains colorado
    A solid engine light?:dontknow:
  11. driverdriver
    driverdriver Road Train Member
    4,254
    5,284
    May 30, 2011
    Yes , not the liquid one.
