- - - - - What engine do you have, for how long and what OIL do you put in it?
Discussion in 'Ask An Owner Operator' started by Lucar, Jan 26, 2014.
What oil do you put in your engine?
  1. *
    Mobil DelvaC
    38.5%
  2. *
    Rotella Shell Triple Protection
    40.0%
  3. Mobil one Synthetic
    3.1%
  4. *
    Shell Synthetic
    7.7%
  5. Mystic
    4.6%
  6. Majestic
    1.5%
  7. Other
    7.7%
  1. me myself and I
    me myself and I Heavy Load Member
    735
    312
    Oct 5, 2009
    vernon hills,Il
    Cummins ISX 1.07M miles. Bought new.Rotella every 18-20k. Usually don't add any oil. Haven't been overhauled. No addictives.
  3. Lucar
    Lucar Road Train Member
    1,396
    891
    Aug 22, 2012
    Texas
    Cat SDP
    60k miles
    Rotella triple action
  4. punksmacker
    punksmacker Bobtail Member
    37
    40
    Jul 2, 2012
    C 15 acert had 250000 miles when purchased now it has 880000, nothing done inside engine,use rotella,no additives, change every 20 thous. Use 3 gallons between oil changes, getting some serious blow by, its time...trying to get to a million before a total overhaul
  5. C-WALSH
    C-WALSH Bobtail Member
    34
    41
    Oct 4, 2014
    2006 DD14L EGR. Delvac with 1 gal Lucas every 15k or less. Oil analysis every other change with no flags. I put in service with 36 miles, now at 981,021 with 8% idle hr's (TRI-PAK APU). Bullgear, rod/main bearings, oil p relief valve, front/rear crank seals all 30k miles ago. 3 turbos, 3 egr's, 1 vpod, 6 injectors (700xxx), 6 overheads, original head and gasket. 5.8 mpg lifetime average and pulls like a freight train with no smoke, ever (except when 1 injector went bad-changed all). She still idles smooth and runs smooth at 1400rpm.
    Lucar Thanks this.
  6. Hurst
    Hurst Registered Member
    6,618
    12,266
    Aug 24, 2011
    Tampa, Fl
    I have an 04 BXS ACCERT C15.
    I drove it for 5 months as a company driver before I bought it in March of 2014.
    It had 994k when I bought it. I have 1,212,778 mi on the odometer right now. Mechanically the truck has been flawless. Electrical, hoses, typical things to expect from a 10yr old vehicle. Most expensive repair was the ECM in June of 2014.
    Bought the truck from my carrier. He was doing the oil changes/PM service every 20k mi. No idea what oil they used. Pretty sure it was the cheapest conventional oil. I've been having it done every 15k mi and using a 50/50 synthetic blend. Mainly to try to eek out as many miles as I can considering the mileage I have.
    I use no oil additives. Maybe once a month I'll buy a couple bottles of injector cleaner/fuel treatment.
    Carrier bought the truck with 600k mi. His records show both turbos, fan, fan clutch, radiator, Alt, air compressor rebuilt, new clutch, and I had the entire A/C system gutted and replaced before I agreed to buy it. Other then tires, new drums and brakes, new injectors last month, I really havent had to do anything major. Mechanically it been a very good truck. My theory was that by 994k mi, what ever was going to need replaced should have been done by then. For the most part I have been blessed and very lucky with this truck.
    Its an 05 FL Columbia. Not the prettiest thing. But reliable as an old dog and best of all its all mine.
    Hurst
    123456 and Lucar Thank this.
  7. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    Detroit 60 12.7 factory reman. 370K miles on engine. Schaeffer 7000 15w40 syn blend. 20000-22500 mile OCI. Uses roughly 1/2 gallon between OCI's. No snake oil.
  8. Lucar
    1,396
    891
    Aug 22, 2012
    Texas
    I have traded my truck for a few months now, I got a 2014 pete with a 500/1850 paccar engine which has turned out to be better than I thought after all the cons I read.
    I will be putting full sync in it after my first oil change which by now I'm only at 35k miles.
    The dealer has told me the intervals are every 40k miles!! Wow that sounds gruesome lol.
  9. jason6541
    jason6541 Road Train Member
    2,425
    5,366
    Mar 5, 2012
    Omaha, NE
    delvac 15/40 30k oil changes on paccar mx now over 500k.
