What ice cooler will keep ice 5-6 days 20 qts?
Discussion in 'Questions From New Drivers' started by RockyTopTn4life, Nov 11, 2017.
  1. 1278PA
    1278PA Road Train Member
    1,170
    1,026
    Dec 5, 2015
    Nope no joke all those coolers are junk I love building and creating stuff been in the trades most of my life. I can build one that will keep the cold in much longer but I'm not sure I'd have time though.
  3. Short Fuse EOD
    2,774
    8,667
    Jul 29, 2015
    Midwest
    I got one of those Coleman coolers with the metal band. It can keep food cold up to 3 days. When my wife puts in big blocks of ice from our deep-freeze, instead of ice cubes from the truckstop, it will last up to 4 days. I have not had any coolers last more than four days. Good luck.
  4. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    If you just want something to keep beverages cold near your seat, you'll be far better off to get a decent thermo-electric cooler. No dealing with water and battery drain is virtually nil. You'll also save money in the short and long term.
    ladr and ncmickey Thank this.
  5. Brandt
    Brandt Road Train Member
    4,515
    6,181
    Sep 17, 2012
    You can get plug in 12v plug in cooler they work good for the cheap price of $135 you leave them plugged in 24/7 and they cool 40f below the can temperature. If you want to spend some money $500-$1500 you can get real 12v frig or freezers. Most have Dan Foss compressor that the trick those don't require lots of power to start or run.
    Engel frig/freezers can go 90f below outside temp. So at 110f you can still keep stuff frozen like but 22QT frig freezer from Engel is $700
    Lepton1 Thanks this.
  6. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    I agree completely. Get a 12v cooler. It will pay for itself within a month or two, because you aren't buying ice.
    An added benefit is you avoid the biology experiment when the ice melts and your food is floating in liquid that leaves a bacterial film over EVERYTHING.
  7. Brandt
    4,515
    6,181
    Sep 17, 2012
  8. ncmickey
    ncmickey Road Train Member
    3,830
    7,145
    Jun 21, 2013
    Durham NC
    298E7871-61A2-4165-AC7D-43447C6A2227.png I used a 12v cooler for this exact purpose. I had a Colman but it was big and bulky.
    I bought this one on Amazon. It is great. I can still step around it going into the sleeper. Keeps plenty of drinks cold.
    When it occasionally ices up, I just turn it on heat and it melts the ice around the fan in about 5 minutes... then it’s back to cold. The fan is also on the top, not the side like the Coleman, so I can use it as an ice cooler if I ever needed to....and not kill the electrics
  9. lilillill
    lilillill Sarcasm... it's not just for breakfast
    5,642
    13,471
    Nov 7, 2007
    Possum Booger, Alabama
    Just in case anyone wanted to know how those thermoelectric coolers work...
    Lepton1 and nax Thank this.
  10. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    Finally a topic that's already on my radar...
  11. BlackThought
    BlackThought Medium Load Member
    562
    462
    Jul 22, 2014
    Memphis,TN
    I have a cheapo Coleman from Walmart with wheels. I buy ice from those small ice shacks. About 3 dollars for 20lbs. Will keep those safe for at least 5days. There will be water and ice. Don't drain the water. Put a thermometer in there if need be.
