What if your ELD stops working in the middle of your trip?
Discussion in 'Trucking Industry Regulations' started by valerchekk, Dec 19, 2017.
  1. valerchekk
    valerchekk Light Load Member
    66
    131
    Feb 8, 2014
    I am using Garmin eLog on my iphone and it just stopped working today. The app just crashes when I try to log in.
    So what should I do in this situation? The dot website says that I have 8 days to fix it and use paper logs meanwhile. My question is, can dot officers still issue a citation/violation for non-working ELD?
  3. Txdriver77
    Txdriver77 Medium Load Member
    365
    26,641
    Sep 7, 2016
    Texas
    always have a logbook with you
    misterG and tech10171968 Thank this.
  4. Dakota1358
    Dakota1358 Medium Load Member
    431
    502
    Jun 15, 2009
    Staunton,Va
    Keep a log book with you at all times. DOT don't care that your ELD isn't working
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    Paper logs and you have 8 days to fix the ELD.
    Tb0n3 Thanks this.
  6. pmdriver
    pmdriver Road Train Member
    2,338
    3,503
    Nov 14, 2017
    Does that mean since all the information on previous days will be lost you have to fill out both?
  7. Txdriver77
    365
    26,641
    Sep 7, 2016
    Texas
    if you cant fix it then yes. i wouldnt trust apps, they freeze and crash all the time.
  8. tech10171968
    tech10171968 Medium Load Member
    627
    851
    Nov 16, 2009
    Daytona Beach, FL
    Indeed.
    In fact, I believe the FMCSA regulation actually requires a driver to have at least 8 days of paper logs to serve as a backup just for that very situation. So rookies are still going to have to learn how to fill out a logbook.
    Tb0n3, Streetroddreams and Bean Jr. Thank this.
  9. pmdriver
    2,338
    3,503
    Nov 14, 2017
    That kind of sucks, you have to do the same job twice unless you have a printer to copy the logs every day or a back up. and they have not thought about that except how to fine the drivers for dang I better stop thare.
    stayinback and Streetroddreams Thank this.
  10. ZVar
    ZVar Road Train Member
    10,911
    23,825
    Sep 10, 2010
    Flint, MI
    Nope. Just blanks in case the ELD goes down.
    As for the last 7 days, it's gets complicated. If you are a company driver the admin should be able to log into the portal and download and fax the logs to you. If you are a single truck, well the real boss of the truck (wife) may be able to do the same.....
    In the event of a malfunction that requires a driver to reconstruct his/her previous 7 days, can a driver use a printed copy of their previous 7 days, such as a PDF copy, instead of manually recording their previous 7 days?
    Yes. In the event that the driver experiences a malfunction that impairs the ELD ability to present the driver’s previous 7 days, the driver may present their previous 7 days by way of any printed copy, or in an electronic form, such as a PDF.
    What must a driver do if there is an electronic logging device (ELD) malfunction?
    If an ELD malfunctions, a driver must:
    1. Note the malfunction of the ELD and provide written notice of the malfunction to the motor carrier within 24 hours;
    2. Reconstruct the record of duty status (RODS) for the current 24-hour period and the previous 7 consecutive days, and record the records of duty status on graph-grid paper logs that comply with 49 CFR 395.8, unless the driver already has the records or retrieves them from the ELD; and
    3. Continue to manually prepare RODS in accordance with 49 CFR 395.8 until the ELD is serviced and back in compliance. The recording of the driver’s hours of service on a paper log cannot continue for more than 8 days after the malfunction; a driver that continues to record his or her hours of service on a paper log beyond 8 days risk being placed out of service.
  11. spyder7723
    spyder7723 Road Train Member
    15,467
    25,010
    Mar 31, 2013
    sarasota, fl
    Submit your electronic log to the office at the end of the day. If you're elog crashes call them up and have them email you the last 7 days and fill in the paper log.
    I swear you guys are either oblivious to what the regs actually say, or look for things to gripe about.
    roshea, Tb0n3 and ZVar Thank this.
