what injector setting for 3406e
Discussion in 'Trucks [ Eighteen Wheelers ]' started by WallyGator, Dec 16, 2008.
  1. WallyGator
    WallyGator Medium Load Member
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    going to cat tomorrow to have work done and thought i would have my injectors reset. my part #or4894. how much more power will i get? thanks Walt
  3. 550hpW900L
    550hpW900L Road Train Member
    1,874
    1,090
    Jan 29, 2008
    norcal
    5232 or 6999 but im not sure if CAT will put these in for ya if they know. 40-50hp.
  4. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    do they need the password to do this?also how do i know which one to go with?
  5. C16KIWI
    C16KIWI Medium Load Member
    575
    142
    Jun 14, 2008
    New Zealand
    No password needed.......5232 40-50hp....6999 about 10hp more again:yes2557:
  6. 550hpW900L
    1,874
    1,090
    Jan 29, 2008
    norcal
    Like Mr. KIWI here said (lol) depending how much you want.
  7. Les2
    Les2 Road Train Member
    5,150
    2,288
    Jul 25, 2008
    kicked back in my lazyboy...
    Did you figure out your other problem Walt?
  8. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    brought it to cat today at my apointment time and was told to come back on friday.no problem going to ocala tomorrow.the cat dealer there told me he would fit me in when ever i come in.i really learned my lesson never again will i darken there door step with my truck.
  9. rockrawlin
    rockrawlin Bobtail Member
    47
    20
    Sep 5, 2008
    Chico, CA
    I had my injector codes and fls/fts set at a KW dealer. Then I went into Cat and had the fls/fts set back to stock. I went back to the same Cat shop and my injector codes changed again 2 more times. Cat told me injector codes are considered a customer specified parmeter and they will change them to whatever you want as long as they aren't password protected (by the owner, not Cat). They didn't charge me either time.
    The Challenger and 550hpW900L Thank this.
  10. WallyGator
    333
    83
    Apr 6, 2008
    Clearwater,Florida
    what are fls/fts.and what do they do. thanks walt
  11. rockrawlin
    47
    20
    Sep 5, 2008
    Chico, CA
    They are full torque and full load (fuel) settings. These other guys like 550, DDS, and Cat Wrench know more about that stuff than I do. When I had mine changed to the hot numbers, all I got was a lot of smoke and heat, and I lost power. I had them changed back and tried just the injector codes and the smoke cleared up but still lots of heat but not much power until I disconnected the wastegate...Then it came alive! I've picked up .9 mph also.
    I'm going to try a bigger turbo as soon as it warms up enough to put one on and then I'll try the fls/fts again.
