What is 6NZ?
Discussion in 'Trucks [ Eighteen Wheelers ]' started by dieselpowerrules, Aug 6, 2011.
  1. dieselpowerrules
    dieselpowerrules Light Load Member
    248
    37
    Feb 24, 2011
    Wisconsin
    I was just wondering what all this code langauge is in regards to Cat engines? The differences and such. Thanks in advance for helping out a newb...
  3. Captain Canuck
    Captain Canuck "Captain of the Ship"
    854
    541
    Apr 7, 2007
    Woodstock, NB, Canada
    These "codes" refer to the first three digits of a Caterpillar engine's serial number, and are related to which generation the engine belongs to. ie: 6NZ/7CZ being a pre-emissions single turbo Cat (and generally the best performing), MBN being a so-called "bridge" single turbo Cat (know to be a sluggish performer but easily programmable through the ecm to 6NZ specs), and finally, MXS/BXS, belonging to the twin turbo Acert family.
  4. Winchester Magnum
    Winchester Magnum Road Train Member
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
    It's the first 3 digits in the serial number. Last year Cat made em was about 2003.
    dieselpowerrules Thanks this.
  5. SmokinCAT
    SmokinCAT Road Train Member
    1,773
    1,487
    Oct 20, 2010
    Hillsboro, OH./ Adrian, MI
    It is a serial number prefix that cat used to identify a series of engines, the 6NZ is the last good single turbo C15, anything after that and your looking at probems created by updated programming and changes in parts used to meet emmissions.
    I believe the build order go something like this, 5EK, 6TS, 1LW, 2WS, 6NZ, and MBN for the single turbo CATs, the first four are considered E models and the last two are C15s.
    The large cube motors go from 5DS, 1MM, and 7CZ, these are higher displacment engine and mostly rated at 600hp with some being 575hp. Also the first two are E models and the last is a C16.
    Hope that clears some things up for you.
  6. dieselpowerrules
    248
    37
    Feb 24, 2011
    Wisconsin
    And the E models were part of the 3406 family correct?
  7. Winchester Magnum
    1,492
    1,647
    Jan 4, 2009
    Alaska highway
  8. Mr. Haney
    Mr. Haney Road Train Member
    2,693
    2,040
    Dec 17, 2008
    The 6NZ is basically a 3406E with some minor upgrades. The electronic are different to allow the engine to communicate with other features that could be installed as options to the truck, AutoShift tranny is one that comes to mind. The other big difference is how the gaskets seal the engine and the reason the C-15/C-16's don't have the oil leaks the earlier 3406E's do. The block is a sculpted block to reduce weight and increase strength.
  9. dieselpowerrules
    248
    37
    Feb 24, 2011
    Wisconsin
    Is it true that the twin turbo Cats are any less reliable than a single turbo? I've heard guys that avoid them like the plague, but I drove one once and really liked the performance.
    Ericfrancs101 Thanks this.
  10. rollin coal
    rollin coal Road Train Member
    13,092
    25,931
    Mar 29, 2008
    TN
    That's the opinion of most probably due to how they had a few bugs early on. I believed it myself until I found this forum and got educated. There's a lot of good info on here about "twin turbo" accerts.they can easily be tuned into the best pulling motor on the road. Check out all the cat threads here especially the " cat power harness" one..
    Ericfrancs101 and Cetane+ Thank this.
  11. dieselpowerrules
    248
    37
    Feb 24, 2011
    Wisconsin
    Now what exactly is the Accert? What makes them different? Sorry for bumping this thread, but Im really interested in Cat engines!
