What is a "real life" pretrip?
Discussion in 'Questions From New Drivers' started by Spyke, Sep 22, 2016.
  1. Spyke
    Spyke Light Load Member
    100
    105
    Jul 29, 2016
    I learned the spiel in school, and I can generally tell which end of the truck should be facing the ground, but I am looking for a source to deepen
    My knowledge of what I should be doing in real life.
    From learning the parts to simple maintenance I can do myself to get back on the road.
    scottied67 Thanks this.
  3. Moose1958
    Moose1958 Road Train Member
    15,199
    33,530
    Dec 17, 2010
    Williesburg, Virignia
    Ah, you want to hear about the phantom pre-trip.
  4. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,137
    Mar 5, 2016
    White County, Arkansas
    It's not a spiel. It is not something to fool with.
    Pretrip is around the truck. Checking everything. You will catch something before it bites you hard 10 miles later at highway speed.
    If your mind is still deflecting the pretrip lectures as a spiel and waste of time, get yourself back home and find another trade besides trucking. Pretrip is a life saver, Your own or someone else. Even if you found nothing around and round and round, trust me something will develop and you will catch it. You are entrusted with a very expensive peice of equiptment and should take care of it like a wife or mistress.
    JV_620, FerrissWheel, SoDel and 12 others Thank this.
  5. RedRover
    RedRover Road Train Member
    1,791
    2,612
    Sep 10, 2016
    Corsicana, TX
    True story: I was at Walmart when a Swift dry van pulled in and shut down for a 34 hour reset. When the driver and his mentor got out of the truck, I did what I normally do and asked them all sorts of questions about how training went and how their miles were etc...
    Turns out, 34 hours later I just happened to be there. They got out of the truck and went inside of Walmart, restocked on a few items and went back to the truck. They fired up the engine and left. Didn't so much as kick a tire after a 34 hour reset. So apparently a pretrip includes purchasing lunch meat and deodorant and nothing else.
  6. tucker
    tucker Road Train Member
    12,647
    40,423
    Jun 13, 2008
    IN
    I do way more than most, I press my thumb against the sidewalls of the tires, I check the lights, if it's dark I check the brake lights, rarely I wedge my broom in to push down the brake pedal and check to see they all are on.
    Maybe once a week I pop the hood and check the fluids.
  7. Redtwin
    Redtwin Road Train Member
    5,491
    7,612
    Aug 17, 2012
    PBC, FL
    Deodorant is of utmost importance when on a team truck.
  8. Chinatown
    Chinatown Road Train Member
    75,551
    172,811
    Aug 28, 2011
    Henderson, NV & Orient
    My pre-trip consists of standing between the sleeper and the drive tires and taking a leak then logging 15 minute pre-trip on the Qualcom. Most drivers won't admit that's what they do.
    @pattyj does exactly like she was taught in cdl school; she physically touches each item and yells out what the item is and what she's looking for. Sometimes a crowd gathers around and stares.
    ethos, Xzay, Dominick253 and 37 others Thank this.
  9. RedRover
    1,791
    2,612
    Sep 10, 2016
    Corsicana, TX
    Chinatown is a wealth of tips and tricks. If the DOT shows up while you're logging the 15 minute PeeTrip, do you tell him that you're looking for any potential streaking on deez here lugnuts?
    Lowlite, kitkat50, Lepton1 and 5 others Thank this.
  10. x1Heavy
    34,017
    42,137
    Mar 5, 2016
    Many drivers just hop into the rig. Then something comes up and you wonder what now? If it's really awesome you can be the next you tube star being discussed here.
    Osiris, Dave_in_AZ and RedRover Thank this.
  11. dca
    dca Road Train Member
    6,834
    11,427
    May 31, 2011
    Earth
    the trick now is to go do it. that spiel should include all the actions and what to look for in the walk around
    were you not paying attention?
