2 weeks ago my clutch pedal went limp and I was unable to get the truck in gear. The pedal was feeling real loose.. I had to call road service and have my truck towed but when I arrived at the dealership it started working again and the company could not figure out what was wrong with it. Just today the same thing happens again I could not go into any gear. I waited an hour this time and it started to work again. It felt like there was an air in the hydralic system or something has anyone had a problem like this?
I drive a 2012 international prostar. I felt real bad the first time because the company had to pay for the tow and assign my load to another driver, and then it turns out to be all for nothing.
what is going on with my clutch?
Discussion in 'Questions From New Drivers' started by A Bug, May 30, 2014.
Page 1 of 3
Master cylinder or slave cylinder might be going bad. Try bleeding it in case there is air in the line
Grubby Thanks this. -
Could also be vapor-locking, if the lines run near the exhaust manifold.
The Clutch Master or Slave Cylinder is on its last legs, replace before it leaves you stranded.
could be the throw out bearing went south or the adjustment was left loose and overlooked by all.i had mine adjusted once and they left it loose and it acted as you described.
First off, before we go with the master/slave cylinder notion, does your truck have a hydraulic clutch? I know the Volvos use them, I know the Kenworth T680 uses them, but this is the first I've heard of International using them.
Seriously though, a clutch either works or it don't. I am curious what the mechanic said when it got to the shop on the hook and now it works. -
I would bet the farm that it's a hydraulic clutch. -
some systems have an air line running to the clutch hydralic unit to help with clutch return I would check that as a possibility. dont know what your driving style is but all you really need a clutch for is to reverse and get the thing in to your first gear.
Page 1 of 3
