What is Gross weight of 2016 coronado wt 70"sleeper
Discussion in 'Ask An Owner Operator' started by Dalpik, Mar 15, 2018.
  1. Dalpik
    Dalpik Bobtail Member
    Hello drivers, i am looking to buy 2016 freightliner coronado it has detroit 12.7 engine,with tandem axle and 70" sleeper & 260"wheel base,since i will be hauling heavier loads sometimes up to 45500 so i need to know what is the gross weight of this truck with full tanks without trailer or what is the gross weight with truck and empty 53' dry van?
    Any help is appreciated.
    Thanks.
  3. Rollr4872
    Rollr4872 Light Load Member
    130
    135
    Feb 5, 2018
    http://www.easttexastruckcenter.com...22721827/2018-freightliner-coronado-132?dlr=1
    I was looking on here and found a 2012 Coronado and a 2018 that matched you specs so maybe it gives an idea for the one your looking at. Each one shows up as having a gross vehicle weight of 52,000. I don’t know if that’s accurate or the average or if that’s with full or empty tanks, but that might be in the ballpark of the average weight of the Coronado trucks.
  4. kw550cat
    kw550cat Medium Load Member
    663
    596
    May 22, 2012
    brooklyn, new york
    You need scale weight now gross vehicle weight. Best guess is 20k but call a company like harrison gliders or fitzgerald and ask for a scale weight or stamped weight
    Dalpik Thanks this.
  5. x1Heavy
    x1Heavy Road Train Member
    34,017
    42,130
    Mar 5, 2016
    White County, Arkansas
    Gross weight combination will be 80000.
    What you are seeking is the TARE weight empty with full tanks without trailer and with trailer.
    The bobtails I was getting prior to 2001 with that size sleeper were hefty at about 18000 each closer to 20000 with me and spouse and everything in it. 53 foot great dane reefer was probably closer to 15000 more empty. Roughly. Give or take a thousand.
    The only way to be sure is to take it to a CAT scale with 11 dollars and weigh it as you like it.
  6. Ridgeline
    22,165
    113,707
    Call the dealer and ask.
  7. nax
    nax Road Train Member
    1,999
    2,253
    Dec 14, 2016
    As @x1Heavy said, the answer you seek is about the same as a Cheeseburger+Fries+Drink at Five Guys Burger = $11
    Then for ketchup, use 7lbs per 1 gallon of diesel to get the half-tank vs. full tank calculation
  8. I glide 47
    I glide 47 Road Train Member
    1,426
    1,523
    Jun 3, 2017
    Should be able to scale 45500. To 46000. My 2016 Columbia and 53 dry van low on fuel maybe just under half. 47000 is possible
  9. blessedman
    blessedman Light Load Member
    296
    230
    Feb 15, 2013
    Doniphan, Mo
    I have a 2016 Coronado like what you are looking at. A glider from Fitzgerald. With a 53' Utility dry van I regularly haul 45,500 to 46,000. Have to watch the fuel on the 46,500 loads.
    You shouldn't have any problem hauling 45,500.
  10. x1Heavy
    34,017
    42,130
    Mar 5, 2016
    Just 45500? Getting a little hefty with those empties are we? Used to be we toss 48000 or a tad heavier into the box at times.
    rearview and Crude Truckin' Thank this.
  11. Crude Truckin'
    Crude Truckin' Alien Spacecraft
    2,377
    6,501
    Oct 22, 2016
    North Dakota, Eh?
    My 2018 old body style Cascadia full of fuel, DEF, and my 6 foot 3 inch 300 pound butt in the seat is right at 21500. ParkSmart has the 4 extra batteries, 280 gallons of fuel, DD15 with all the emissions junk, 2 pairs of 3 rail chains, 1 pair of singles, sliding fifth wheel, full lockers, deer bumper, all adds up I guess.
    x1Heavy Thanks this.
