What is on DOT records?
Discussion in 'Questions From New Drivers' started by gdyupgal, Aug 21, 2012.
  1. gdyupgal
    gdyupgal Medium Load Member
    630
    434
    Aug 21, 2010
    Montana/Watford City,ND
    I got to think'n about another thread about DOT record/info about false info...so what exactly is on that record? Does it have evry DOT regulated employer we have ever worked for on it? I'm helping my friend fill out an aplication and he asked me if he had to list all his employers as he has one employer he doesnt want to list because well he and a dispatcher squared up and he bonked the dispatcher in the nose...oops...I knew the situation and actually any one would have been hard pressed not to take the disp. Head off but needless to say does he have to list that employer....What does a company see when they pulll a DOT record? Phewwww my fingers cramping hahaha..TIA
  3. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    DOT doesn't keep records on drivers . You may be thinking of a DAC report but many companies don't give them any info.
  4. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    How long did he work for the company where he bonked the dispatcher ? If he doesn't list it howwill he explain that gap in employment ?
  5. gdyupgal
    630
    434
    Aug 21, 2010
    He said there is only a 2 month gap and beccause up here alot of us work alot of hrs and the we can take several weeks off so he's just putting that he went home for that time...I was just reading the aplication and you are correct HireRight. So what info does hireright have...sheesh it's like the old west here hahaha more brawls and lady steelers then Ilve ever seen hahaha
  6. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
  7. gdyupgal
    630
    434
    Aug 21, 2010
    So I guess he has to wait however long to get that report backk to know what if any of his past employers on it before he submits an ap. Or take his chances and submit it..
  8. RickG
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    If he rally needs a job submit it but not to a company he thinks might be real good to work for later .
  9. Grumppy
    3,055
    10,373
    Dec 11, 2010
    West Monroe, La
    I am guessing that Hireright is the company that most employers use...??? Is it the ONLY place that DAC reports are collected, stored, taken, given or provided?
    I guess what I am asking is, for example there are three credit reporting agencies. Equifax & them other two. Does DAC reporting work the same way or, is this basically the only place? Anyone know?
  10. mamamullins
    mamamullins Medium Load Member
    307
    174
    May 4, 2011
    Ingalls, IN
    Grummpy, when you submit for a copy of your DAC report, there is a membership that you can take advantage of through hire right that will allow you to access your CSA, DAC, background checks, and mvr's. Here is the link to hire right that explains how all of the information is obtained in one report.
    http://www.hireright.com/DAC-Online.aspx
    Gdyupgal, I know that most companies require all company drivers to list all transportation jobs for a 10 year period, so that they can account for all dates. The reason for this is because of the homeland security check. The companies will only ask start date, end date, and reason for leaving. If he needs a job and cannot wait for the DAC report, then I would suggest to list it to make sure that all time is accounted for. Trucking companies look at the DAC report for any preventable accidents, incidents, CSA scores, moving violations, and MVR's to see if the driver meets their qualifications. If the company he worked for was a small company then I highly doubt that they reported anything to DAC.
    gdyupgal Thanks this.
  11. snowwy
    snowwy Road Train Member
    20,527
    13,262
    Jul 6, 2009
    dac is something some stupid idiot started. and is mainly affiliated with major carriers.
    if he never worked for a major carrier. he's probably safe.
    only thing i have on my dac. is my training and that was 13 years ago. i stay away from people that use dac.
