What is the advantage of trailers having disc brakes?
Discussion in 'Experienced Truckers' Advice' started by TruckRunner, Jul 2, 2018.
  1. TruckRunner
    TruckRunner Heavy Load Member
    704
    3,270
    Dec 21, 2017
    Because I have a brake problem and no one has disc brakes in stock so do the advantages outweigh that if there is a problem no one carries them? I remember six years ago I had the same problem but I figured by now they would be more available.
    rabbiporkchop, MartinFromBC and rank Thank this.
  3. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Superior stopping power and like 8x service life...
    Trailer dealer doesn't have the parts you need?
  4. Oldironfan
    Oldironfan Road Train Member
    5,776
    5,541
    May 22, 2017
    8 times more service life?
    Not when people over heat them and warp the rotor.
    8 times more expensive more like.
    D.Tibbitt, TruckRunner and stillwurkin Thank this.
  5. gokiddogo
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    Company drivers maybe burn them out quickly...
    The cost is approximately double. So all the way around it's a no brainer for new equipment.
    I didn't think so until I tried them.
    Oh and no pushrod measurements.
    RubyEagle, PE_T, SuperRookie and 5 others Thank this.
  6. GasHauler
    6,257
    4,365
    Oct 23, 2005
    Vegas/Jersey
    I know that Texaco tried them back in the 90's. I don't think they had the disc on when they spec'd their trucks after that. The cost were preventable so I think they went the cheaper way. Smarter way too since the disc showed no real gain over the drum brakes.
  7. Meteorgray
    Meteorgray Heavy Load Member
    754
    597
    Jan 1, 2016
    I remember when disc brakes first became popular with racing cars. The theory then was the discs didn't necessarily stop the car better, but they tended to cool off faster in the curves, so they maintained their braking power longer when heavily used. Don't know if things have changed that.
    SuperRookie and Oldironfan Thank this.
  8. not4hire
    not4hire Road Train Member
    7,142
    26,957
    May 16, 2012
    Calgary
    Why is this even a question?
    It's like, "is the earth flat?"
    Airplanes, cars, motorcycles, bicycles... drum brakes are a relic.
  9. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    It isn't just that discs cool quicker-- which they do, thus retaining their effectiveness and significantly reducing heat-soak-- but drums also expand with heat reducing their effectiveness due to increased distance between drum and shoes. Discs are also "self-adjusting" to compensate for wear, heat, etc.
  10. Oldironfan
    5,776
    5,541
    May 22, 2017
    Earth is round, and spherical.
    not4hire Thanks this.
  11. not4hire
    7,142
    26,957
    May 16, 2012
    Calgary
    The only time drums are superior is on initial application in the rain, but that advantage is quickly erased.
    Hammer166, Lepton1 and rabbiporkchop Thank this.
