What is the difference between 40k and 46k rears?
Discussion in 'Ask An Owner Operator' started by Thotphobia, Mar 23, 2022.
  1. Thotphobia
    Thotphobia Light Load Member
    69
    47
    Apr 21, 2021
    Hi guys, I’m fairly new to the trucking business, I just wanted to know what’s the difference between 40k rears and 46k. I can’t seem to find the right answer. We’re trying to buy a semi, but want to figure out what’s best for us. We haul logs, most of the time more than 80k pounds. Thanks!
    ProfessionalNoticer Thanks this.
  3. ProfessionalNoticer
    2,941
    7,858
    Apr 25, 2021
    Added strength. The higher the number, the stronger (and heavier) they are.
  4. Animosus
    Animosus Heavy Load Member
    730
    2,892
    Dec 7, 2015
    SE Wyoming
    That one is rated at 40k and one is rated at 46k.
    Big Road Skateboard Thanks this.
  5. Cat sdp
    Cat sdp . .
    21,196
    75,208
    Apr 8, 2012
    Orion's Belt
    The 46k also have more gear oil capacity and probably also have thicker housing walls it was an option when I spec’d mine…..
    unless your hauling 100k lbs every load the 40k will do the job. But the more important thing in logging is what’s the ratio of the rears ?
  6. Big Road Skateboard
    6,721
    37,835
    May 2, 2021
    Either should work for you. I assume you're not worried about being over 80k gross? If not, you can at times find heavy specd trucks cheaper on the used market, because of their added weight it makes it tough to haul a full load for most folks not hauling heavy.
  7. Dino soar
    Dino soar Road Train Member
    4,809
    26,922
    Dec 8, 2017
    Also realize that everything is heavier on 46,000 lbs rears versus a 40,000. Heavier bearings, axles, gears, housing, et cetera.
    Everything is more expensive to repair when the time comes.
  8. Thotphobia
    69
    47
    Apr 21, 2021
    This one we looking at is at 3.73
  9. Thotphobia
    69
    47
    Apr 21, 2021
    Sometimes we’re at 90k. But average 84k.
  10. Thotphobia
    69
    47
    Apr 21, 2021
    It’s a 46k with 3:73s 10 speed, C15 Cat
  11. Cat sdp
    Cat sdp . .
    21,196
    75,208
    Apr 8, 2012
    Orion's Belt
    What size rubber?
    I’d guess 24.5 , those would be better off road. But at 84K either will be fine. You won’t be in the 8 mpg crowd but it’s a decent working truck set up…..
