I am confused, I always thought they were the same thing but in NY, it's different and am hoping someone can just clarify this for me. Thanks.
What is the difference between a "tractor-trailer" and "truck-trailer"?
Discussion in 'Questions From New Drivers' started by NY2001, Jul 22, 2022.
Check the "Definitions" section of the FMCSR.
Tractor trailer is a vehicle without a body, just a 5th wheel hitch designed exclusively to haul a semi-trailer using a kingpin/5th wheel coupler.
Truck trailer combination is any truck and trailer combination that does not meet that definition such as a truck with a pickup body, hauler body or even a dump truck or similiar vehicle pulling a trailer. Truck trailer combinations can have a 5th wheel, gooseneck or ball type hitch.
The truck title and registration will have a "brand mark" such as TK or TT to distinguish how the state identifies the vehicle.
The distinction is important for obtaining an unrestricted class A CDL, use the truck trailer instead of a tractor trailer and you will have a restricted license. It is also important for allowable overall length, a tractor trailer has no overall length restriction just the trailer length is limited while a truck trailer is limited to 65' overall length from front of truck to rear of trailer.Val_Caldera, Grumppy, God prefers Diesels and 5 others Thank this. -
Some tractors don't have a fifth wheel. Instead they have either a box or a flatbed deck or a tank mounted behind the cab. Then they have a trailer, 20 to 28 ft long and up towed behind attached by a pintle hitch. These were called a truck and trailer when I worked loading trucks when I lived in California.
Val_Caldera, okiedokie and Flat Earth Trucker Thank this. -
Everything in trucking has 408 names, plus regional differences. Each one will be defended as THE ONLY name for the thing.
Tractor has fifth wheel job. It's useless on it's own, yet powerful freight machine when coupled with trailer.
The truck has steer tires and cargo on same frame.kylefitzy Thanks this. -
NOTHING!
they are interchangeable terms.
there is a further distinction between the types of trucks/tractors, like day cabs or sleeper cabs. -
Easiest way is think of a dump truck also pulling a dump trailer.
Fuel truck also pulling a fuel trailer.
Both are ‘truck/trailer’
Tractor with semi trailer sitting on fifth wheel, is ‘tractor/trailer.
Truck/trailer, and Tractor/trailer, no need for doubles endorsement. -
look up semi-trailer VRS full trailer.
a truck and full trailer would be a truck with a freight body pulling a full trailer, all class 8 equipment
a tractor and semi trailer uses a fifth wheel to support the semi trailer but a full trailer could stand alone...
Then you can look to Canada for Aaaah train VRS B train too
