What is the optimum weight distribution?
Discussion in 'Questions From New Drivers' started by Skydivedavec, Aug 15, 2014.
  1. Skydivedavec
    Skydivedavec Medium Load Member
    640
    536
    Sep 12, 2013
    Mid-Atlantic
    OK, so in school and during training weight limits were effectively drilled into my brain and shall forever remain. But what about the distribution of weight for other reasons, primarily for a more comfortable ride? No one ever said to me what ratio I should try to achieve, only what maximums to avoid.
    Veterans? Thanks.
  3. Powder Joints
    7,680
    7,771
    Sep 25, 2007
    Rosamond, SoCal
  4. Snowshoes
    Snowshoes Heavy Load Member
    878
    664
    Sep 23, 2012
    Pleasant Grove, Utah
    I agree, well balanced, but good luck with that one...just sayin...:biggrin_25513:
    Skydivedavec Thanks this.
  5. Skydivedavec
    640
    536
    Sep 12, 2013
    Mid-Atlantic
    Thanks PowderJoints, I guess this is a no brainer but when you're a Newby one wonders. I have certainly felt the effects when something just isn't right and you feel like you're leap frogging I-440 around Little Rock. I appreciate the quick response.
  6. Skydivedavec
    640
    536
    Sep 12, 2013
    Mid-Atlantic
  7. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    Fuel mileage? More weight on trailer (trailer tires/axle have lowest rolling resistance, tandems closer to tractor means they are closer to the 'draft')
    Braking? More weight on the trailer
    Maneuverability? More weight on the trailer (tandems forward = shorter wheelbase)
    Forward traction? More weight on the tractor/drives
    Ride (for you)? More weight on the tractor/drives
    Ride (for load)? Evenly balanced (to the extreme: slide 5th wheel back for less weight on steers)
    Does any of it matter all that much? Not really
  8. bhcv
    bhcv Bobtail Member
    22
    10
    Aug 24, 2011
    Portland Oregon
    "comfort" should never but a deciding factor for weight distribution. The tire(s) with the least amount of weight have the greatest chance of loosing traction. Loose of traction equal lose of control. 10k on the steer, 19k on the drives and 34k on the trailer is a dangerous potential jackknife situation. The same load adjusted to 11, 26, 26 would be my goal.
  9. Pahrump
    Pahrump Medium Load Member
    Steering axles are designed to have weight,,If you have a 12,000# steer getting as close to 12,000# allows the front suspension to work as designed,,as for the drives and trailer even as possible with a more on the drives,,very hard to get proper braking and traction with trailer tandems having more weight that the drives.
    Steer axles and drives do more braking than trailers,, my goal would be 11, 30, 22
  10. wore out
    wore out Numbered Classic
    15,929
    192,771
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    25 ton in the front hopper and 26 in the back hopper. She rides like a Cadillac and all axles are good on individual weights it realize you probably don't pull a covered wagon but the basics of that formula apply across the board
