stupid question for a newbie??
what is the PTO???
is that a power option on car haulers or for other trucks??
texascajun83
forgive me for asking but im interstesd in learing about trucks and stuff..
what is the PTO ??
Discussion in 'Questions To Truckers From The General Public' started by texascajun83, Feb 3, 2013.
PTO is just a other name for automatic pilot,like in planes..
all trucks have it now so the drivers can take a nap. -
PTO = Power Take Off.
It's a mechanical means of either powering a hydraulic pump or other mechanical device off the transmission.volvodriver01 Thanks this. -
Power Take Off, used to power a pump, usually, can be a hydraulic pump, or a blower for a dry tank or even a mechanical liquid pump on a liquid tank, other uses, too.
More used by straight trucks, nearly all of the fuel trucks that I have seen use a PTO operated pump.volvodriver01 Thanks this. -
According to Wikipedia:
A power take-off or power takeoff (PTO) is any of several methods for taking power from a power source, such as a running engine, and transmitting it to an application such as an attached implement or separate machines.
Most commonly, it is a system comprising a splined output shaft on a tractor or truck, designed so that a PTO shaft, a kind of drive shaft, can be easily connected and disconnected, and a corresponding input shaft on the application end. The power take-off allows implements to draw energy from the engine.
Most commonly, I have seen a PTO on dump trucks.
Truck transmissions have one or more locations which allow for a PTO to be mounted. The PTO must be purchased separately and care is required to match the physical interface of the transmission with a compatible PTO. PTO suppliers will usually require details of the make, model and even serial number of the transmission. Care is also needed to ensure that the physical space around the transmission allows for installation of the PTO. The PTO is engaged/disengaged using the main transmission clutch and a remote control mechanism which operates on the PTO itself. Typically an air valve is used to engage the PTO, but a mechanical linkage, electric or hydraulic mechanism are also options.
Units will be rated according to the continuous and intermittent torque that can be applied through them and different models will offer different "PTO shaft rotation to engine RPM" ratios.
In the majority of cases, the PTO will connect directly to a hydraulic pump. This allows for transmission of mechanical force through the hydraulic fluid system to any location around the vehicle where a hydraulic motor will convert it back into rotary or linear mechanical force. Typical applications include:
- Running a water pump on a fire engine or water truck
- Running a truck mounted hot water extraction machine for carpet cleaning (driving vacuum blower and high-pressure solution pumps)
- Powering a blower system used to move dry materials such as cement
- Raising a dump truck bed
- Operating the mechanical arm on a bucket truck used by electrical maintenance personnel or Cable TV maintenance crews
- Operating a winch on a tow truck
- Operating the compactor on a garbage truck
- Operating a Hiab/Grapple truck
volvodriver01 and 25(2)+2 Thank this. -
dutchieinquebec Thanks this.
sorry
but its 2013 everybody has or knows google ,wikipedia and her we gett those questions
http://en.wikipedia.org/wiki/Power_take-off -
Driving a 6 wheel tow truck in the 70's, we had PTO's that engaged the winch which operated the tow bar.
wis bang Thanks this.
The tractors you see pulling a mower, cutting grass on the interstates, have a PTO that runs the mower assembly.
