Tinkering with
My 94 379 and I found this air leak. The part in on firewall near the city horn. It got dark on me so I did not try and trace the air lines down.
it is wet in photos as I just sprayed it with soapy water.![]()
What is this part on Peterbilt 379 by city horn
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by staceydude, Aug 24, 2021.
Think it's the solenoid for engine fan. I think
Klleetrucking, Last Call, Oxbow and 3 others Thank this. -
Looks like the engine fan solenoid.
Klleetrucking, Oxbow, Roberts450 and 1 other person Thank this. -
That is what I was thinking as the exit runs up towards front of motor. Leaking pretty bad.
I’ll be able to see it in the morning a bit better.
thanksOxbow Thanks this. -
Here is a short video
Looks like a filter attached to the solenoid. I am wondering if it is loose.
Looks like it has been on there for some years so I will more than likely replace it and the solenoid.
Could be the oring on that bowl or it might just need to be tightened a little
Did you try unscrewing the bowl?Oxbow Thanks this. -
Oxbow, Klleetrucking and RocketScott Thank this.
