Took dash panel off with speedometer and such gauges mounted to it to find a water leak and found this unit back there. looks like a relay. And looks to be a 2 piece of some sort becuase there is a heavy gauge yellow jumper wire going from one unit to the other as pictured. Can’t be for starter. Starter relay is mounted to firewall on outside and starter solenoid is mounted to starter. Thanks
What is this unit behind the dash. 2002 pete 379
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by Cam Roberts, Nov 26, 2018.
Is it your low air buzzer?
All that stuff is down on the floor my friend. There is 2 low air pressure sensors and changed them both out. This one puzzles me. And the fact that there is a pretty heavy gauge jumper wire on there
Oh ok. My buzzer is behind my dash and looks similar to that.
Cam Roberts Thanks this. -
It’s a Bomb. Do not go slower than 55 mph in the construction zones.
AModelCat, Cam Roberts and JohnC123 Thank this. -
Accessory relay. It feeds the key on side of fuse panel.
Main cab relay/circuit breaker
Cam Roberts, SAR, JohnC123 and 1 other person Thank this. -
Ok thank you. Just good to know where things are and what I’m looking at if I ever have an issue somewhere. Thanks again
