What is valve called that releases air from airbags on tractor?
Discussion in 'Ask An Owner Operator' started by Forever237, Aug 10, 2022.
  1. Forever237
    Forever237 Light Load Member
    122
    63
    May 29, 2016
    Mine is working abnormally. When hooked to trailer and pressure on air bags rises it opens up and leaks.
    What is it called?
  3. D.Tibbitt
    152,843
  4. Forever237
    122
    63
    May 29, 2016
    I’m the one asking here lol
    Does it release air when bags are under pressure?
    Rideandrepair Thanks this.
  5. Last Call
    Last Call Road Train Member
    7,568
    45,909
    Mar 15, 2021
    This ^^^^^^
    Rideandrepair and D.Tibbitt Thank this.
  6. Big Road Skateboard
    6,646
    37,321
    May 2, 2021
    It doesn't release air under pressure though. Do you have s pic where it's leaking?
  7. Forever237
    122
    63
    May 29, 2016
    Several times tried to catch the leak unsuccessfully.
    So, I have previous posts about my truck having problem with my air dryer. When going uphill it is working fine. As soon as I start descending, purge valve on airdryer starts purging every thirty seconds until it stops (I don’t know why… overwhelmed maybe) and air tank pressure goes up to 145 psi until Safety Valve starts releasing air. Yesterday at dark I stopped to take a look and something is leaking somewhere in rear suspension area.
    My guess is at uphill angles this leveling valve is fine but leaks at downhill which would explain why purge valve starts kicking every 30 sec or less.
    Is my theory realistic because I’m changing leveling valve tomorrow? Or am I wasting money?
  8. RebelChick
    RebelChick Road Train Member
    2,826
    5,430
    Jan 2, 2012
    Coastal VA
    Is it making a rapid tsk, tsk, tsk noise repeatedly until your alarms come on for your air pressure?
  9. Forever237
    122
    63
    May 29, 2016
    When I’m unhooked from trailer,
    No. It is leaking only when driving. Especially after uphill going downhill. Like I mentioned above, after downhill yesterday I stopped briefly to see what’s going on. Noticed vivid leak from rear side (constant leak). Was on very narrow street, nobody around, in the dark. So decided to find safer place. The next stop, leak is gone.
  10. 77fib77
    77fib77 Road Train Member
    11,302
    73,428
    Jul 7, 2010
    St Louis
    It might be it leaks when then line deflects out of position. Is a leveling valve a lot of money? You could change it out and see if it fixes it. If I push on mine side to side it leaks but I haven't changed it yet. It's not horrid.
    Rideandrepair and Forever237 Thank this.
  11. D.Tibbitt
    152,843
    So get under there with some soap and water and find where it's coming from. To me it sounds like a leveling valve. It will exhaust air out of it if the o ring inside is shot
    Rideandrepair, Forever237 and 77fib77 Thank this.
