What is your average rate per mile? Van and Flat.
Discussion in 'Ask An Owner Operator' started by comoes3, Apr 18, 2013.
Are you OK with your avg rate per mile?
  1. *
    Yes
    61.9%
  2. *
    No
    42.9%
  3. *
    No choice!
    4.8%
  1. comoes3
    comoes3 Light Load Member
    52
    9
    Mar 23, 2013
    Austin TX
    I wanted to know what others are getting on average empty and loaded miles.
    I dispatch a flatbed and our average empty and loaded is 2.25 per mile. (no tarp) (Interstate)
    The van on the other side averages 1.90. Intrastate Only (Texas)
    I think these are good numbers but would like to know what others are getting, and what you think of it?
    We operate out of Austin Texas.
  3. carrkool
    carrkool Heavy Load Member
    883
    495
    May 10, 2012
    adah, pa
  4. mcgoo422000
    mcgoo422000 Medium Load Member
    529
    174
    Mar 18, 2012
    I use 2.60-80 a mile or sometimes more. I go home empty a lot to but at 10-12 MPG empty I don't worry about it.
  5. comoes3
    52
    9
    Mar 23, 2013
    Austin TX
    For a flat? With tarps?
  6. snowwy
    snowwy Road Train Member
    20,537
    13,274
    Jul 6, 2009
    only way i can hit 10 is WITHOUT the trailer. and i've driven a few trucks
    FLATBED Thanks this.
  7. Saddletramp1200
    Saddletramp1200 Road Train Member
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    Depends on what you want me to pull. Very vague question.
  8. Saddletramp1200
    2,111
    2,836
    Sep 4, 2011
    Houston Texas,USA
    I'm not a bad guy. I show up with a float, you want a step deck, It's office work. I will comply, but don't leave me in the dark.
  9. spyder7723
    spyder7723 Road Train Member
    15,470
    25,061
    Mar 31, 2013
    sarasota, fl
    yes very vague question. also is that "to the truck" rate or is it carrier rate and truck sees a percentage of it. is it heavy, light. fast to load/unload? need more info to give you a true answer
  10. comoes3
    52
    9
    Mar 23, 2013
    Austin TX
    Overall average
    Carrier rate, under your own authority. I mean a combination of all the above.
  11. spyder7723
    15,470
    25,061
    Mar 31, 2013
    sarasota, fl
    ok, weight can still make or break a rate. also expected load and unload times. area of the country, time of year. commodity. a ton of things go into a rate quote
    you mentioned intra state, in texas. it would take a lot more research into Texas' particular market and the commodity you are hauling, in order to make a reasonable comparison. the more important thing is does that rate work for you. If it works for you, and you can make a good living on it, then it doesn't matter what the rest of us would need to run those loads.
