what is your mpg?
Discussion in 'Questions From New Drivers' started by TruckerPete1990, May 16, 2013.
  1. TruckerPete1990
    TruckerPete1990 Road Train Member
    8,623
    5,377
    Jul 16, 2012
    Bentonville Arkansas
    So our truck's run 70. I'm only seeing a 5.2 mpg...
    Here is what I'm trying to see if anyone else that runs this speed is getting a better mpg. We run close to 80000 most of time.
  3. Pound Puppy
    Pound Puppy Heavy Load Member
    974
    868
    May 31, 2010
    Amherst, OH
    That will be accurate. Try cutting back to 65. My overall is 7.3mpg but I rarely pull heavy. Ive gone as high as 8.1mpg some weeks. There are a lot of factors in fuel mileage. Type of trailer, type of truck, aerodynamics. Also idleing will kill mpg. I have an apu that helps a lot. Also truck set up is important. I have a 475 Cat 18spd OD 3:25 rears. This set up keeps my rpms low at cruising speed and helps my mpg. At 70mph I only turn 1325 rpm. So theres a lot to take into account.
  4. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Where you run, what altitude you typically operate in (air density), flatbed or van, APU runs a lot, what your average gross is ... these are the most critical parameters to consider when comparing MPG across different drivers and fleets. Furthermore, you need to look at a minimum of 1 month accurate fuel addition tracking and miles.
  5. silenteagle
    silenteagle Road Train Member
    1,491
    795
    Oct 23, 2011
    Ozark, MO
    Lifetime MPG on my '12 Cascadia is 7.9. I am currently at 79990 running from Washington state to Maryland. AVG 8.16 and climbing as we cruise across Indiana. I am almost always heavy and I run 57-62.
  6. J_FROG
    J_FROG Road Train Member
    1,061
    564
    Sep 4, 2011
    49 states and Canada
    12 Cascadia, always heavy, run east of I69 usually, with student avg is 6.5-6.8. Without student 7.0 to 7.8 goverened at 63 but well worn drives steal mileage and speed is usually 61.
  7. sourdiesel
    sourdiesel Light Load Member
    117
    81
    Aug 24, 2011
    warrenton,va
    I get about 6.5 to 7.5 most of the time, but road, wind and temp play a big factor.
  8. HotH2o
    HotH2o Road Train Member
    4,098
    4,865
    Sep 23, 2012
    I'm in a 2012 Volvo and it gets about 8-9mpg. I run 79k every load.
  9. russellkanning
    russellkanning Medium Load Member
    640
    142
    Jan 22, 2012
    Frost, TX
    i only see 70 downhill or downwind :)
  10. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    2001 Volvo 770, N14, 13 spd, Dryvan 18k to 78k loads, 7.6 MPG Average,
  11. midnightrunner
    midnightrunner Bobtail Member
    49
    18
    Oct 11, 2012
    La Crosse WI
    During the summer i get 6.6-6.9 and i rarely shut the truck off, governed at 65(64 in reality). Gross ranges from 55-75k, and im in a big square truck. 2000 Pete 379 1,560,000 miles. C12, eaton 10, 3.73 rears. Not bad for a company truck
