What kind of batteries to use for 2016 cascadia
Discussion in 'Ask An Owner Operator' started by joseph1853, Jan 27, 2023.
  1. joseph1853
    joseph1853 Road Train Member
    1,003
    562
    Dec 12, 2010
    Waco, TX
    There telling me there's two batteries for my truck at the freightliner dealership. Ones the Odyssey brand $500 each and the other is the alliance east pen for $100 each. There recommending the odyssey batteries it comes with apparently from the factory. The truck has odyssey batteries in it currently. I bought the truck with them in it which tells me i should probably put those in it. What do y'all put in your trucks?
  3. abyliks
    abyliks Road Train Member
    3,997
    9,399
    May 2, 2010
    ludlow MA
    Go to Napa and buy them they use dekka, I won’t use anything else any more
    Pittstruck, 1mm3406e, ducnut and 2 others Thank this.
  4. nredfor88
    nredfor88 Road Train Member
    1,801
    6,098
    Sep 26, 2019
    USA
    Be careful with Odyssey. When I was researching batteries for deep off-road 4 wheeling a few years ago I learned that the former good reputation they had was tarnished in many reviewers opinion, after they moved out of their US plant. Apparently the quality dropped. I don’t know if that’s still currently the case or not.
    ducnut and joseph1853 Thank this.
  5. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    I've never had luck replacing less than that always end up with the same problem again later. AGM last longer, don't lose hardly any cranking power in cold temps, but cost more. In your situation I'd probably replace them all with lead acid. Myself I prefer agm except last year when they needed replacing (first time 2016 truck) they were unavailable because covid. The cost was about 110 each for what I have vs 350 I think it was each for agm, not odyssey. Odyssey agm were going to be about 600 a piece. These are all cdn$.
    Someone else may need to correct me here but I'm not sure it would be wise to have a mix of agm vs lead acid. At 500 the odyssey had better be agm and the 100 will be lead acid.
    joseph1853 Thanks this.
  6. Ridgeline
    22,609
    120,130
    I second this ...
  7. kwswan
    kwswan Road Train Member
    1,988
    10,756
    Jul 26, 2009
    mcminnville,tn.
    Another vote for Napa.
  8. ApeHangerGod
    ApeHangerGod Bobtail Member
    25
    14
    Aug 28, 2018
    You don’t need that high dollar battery. Shop around before you buy, I ended up buying my batteries at Freightliner last month for cheaper then I could get them at Walmart.
  9. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,750
    16,653
    Jan 18, 2011
    Go to Deka.....buy 4 thousand crankin amp blems
    Same batteries 1/2 pricr
    Rideandrepair and joseph1853 Thank this.
  10. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    Called them and they said there not available in our area. The dekka brand that is. She saw them on the computer there just none around here I guess. She had the Napa brand though for $170 each. Lead battery. Funny thing is Freightliner has the same batter for $98.
    Rideandrepair and ducnut Thank this.
  11. joseph1853
    1,003
    562
    Dec 12, 2010
    Waco, TX
    I called Freightliner back to verify what type of battery the odyssey was and they are agm. $650 each which is $250 more then what they quoted me yesterday. Weird.
    What do you mean you never had any luck replacing less then that? Less then what?
    So you don't think running lead vs's agm would cause any electrical issues? The guy I talked to at Freightliner seemed to thank it could since that come out of the factory with these agm battery's and all.
