what kind of oil in motor ?
Discussion in 'Ask An Owner Operator' started by Edgar2191, Jun 8, 2013.
  1. Edgar2191
    Edgar2191 Light Load Member
    178
    33
    Apr 9, 2013
    What type of oik do you use? What brand weight do you change it for the summer different oil in winter
    It matterd im asking for anb09 cummins isx engine with egr
  3. Edgar2191
    178
    33
    Apr 9, 2013
    Sorry on mobile for spelling and I tried to search but didnt find any result
  4. RollingWave
    RollingWave Bobtail Member
    33
    6
    Jun 8, 2013
    15W-40 will do
    SheLL Rotella and Mobil Delvac seem to be the most trusted brands
  5. snowwy
    snowwy Road Train Member
    20,556
    13,284
    Jul 6, 2009
    i've got shell in right now. 10,000 miles and i'm losing oil presssure.
    never have that problem with mobile1.
    isx only likes mobile1. the last truck i drove had a sticker on the frame specifically recommending that oil.
    you get better fuel economy. engine runs quieter. cooler. and oil pressure stays higher.
    i can shut down for 10. and the temp guage still reads. shut down for 2 with mobile1 and the temp guage won't read.
    i've also seen leaks that disappear with mobile1.
    areelius Thanks this.
  6. Dryver
    Dryver Road Train Member
    2,818
    2,575
    Nov 30, 2008
    Sioux Falls, SD
    I use Mobil, but nothing wrong with Shell. I think keeping to a schedule and not trying to stretch the miles between changes and filters is the key. In the long run it is a false economy to save a few pennies running old oik.
    1976bigred Thanks this.
  7. rollin coal
    rollin coal Road Train Member
    13,292
    26,839
    Mar 29, 2008
    TN
    Oil is oil. Pick a brand of 15w40 and stick with it. Some people use the cheapest brand every change to no ill effect. Regular oil samples tell the story.
    Sent from my droid using Tapatalk 2
    heavyhaulerss Thanks this.
  8. Stump
    Stump Heavy Load Member
    769
    663
    Jan 27, 2009
    Modesto CA
    I use 5-40 Mobile synthetic, with a OPS Ecopure bypass filter. 870,000 miles on a C-15 Accert, set the ping timing a few weeks ago, the compression is like a new engine. Only use a gallon every 15,000 miles. Oil samples are like a blood test for your truck, you can't tell problems by ignoring them and just draining and replacing.
  9. Roadmedic
    Roadmedic Road Train Member
    18,951
    8,981
    Apr 4, 2007
    I use Rotella 15 40 .
    888,000 on the motor. Will be due for another oil test in 12,000. Last one said it was like a new engine.
  10. wwp2343
    wwp2343 Light Load Member
    84
    7
    Jun 14, 2010
    PA
    Amsoil OE 15w-40
  11. Johny41
    Johny41 Road Train Member
    1,192
    1,020
    Feb 10, 2011
    Ontario, Canada
    I use synthetic only ,summer and winter 5w40 Rotella T6 or Mobil ; no additives ;and change it every 25k. I have 1,120,000 milles on original motor Volvo D13, with egr /dpf.(Volvo 780/ 2008 ),still running great 8-9 mpg. I buy in gallon jugs from Wall Mart,Meijer for about 20$ /gal, my motor needs 9 gallons, I don't trust bulk synthetic from lube shops, I had problems in cold weather with synthetic oil from Speedco .
