What kind tests to see how much life my c11 got?
Discussion in 'Ask An Owner Operator' started by T800mfer, Dec 22, 2023.
  1. T800mfer
    T800mfer Bobtail Member
    Picking up an old Haliburton t800, 07 yr, 250k, 23k hrs.
    It'll be using its wet kit, doing aggregate work.
    My concerns are the high engine hrs.
    My initial thought process when buying the truck was that since the frame looks brand new.
    Hopefully it just did short runs in Oklahoma and sat all day.
    Looking for experiences with either old Haliburtons bought and put to work.
    How to test for certain signals that'll tell whether she's got another yr or two before an Overhaul.
    Or most importantly, any #### information on c11's!
    Doesn't seem like anyone really ran these compared to c13's.
    Don't go easy on me.
  3. abyliks
    abyliks Road Train Member
    3,996
    9,394
    May 2, 2010
    ludlow MA
    We have 2 c12s in the yard, they aren’t bad, but you know you are driving a small block
    you are buying a truck that needs a motor and price should reflect that
    Vampire and AModelCat Thank this.
  4. North Pole Nightmare
    North Pole Nightmare Heavy Load Member
    949
    1,836
    Dec 15, 2021
    Is it red or white?Frac trucks were red,the white ones hauled chemicals,their chemical division.They were trading out 10 year old trucks when I was there last year.If it's an 07 someone else has probably been running it.The red t800's on the frac crews had about 50,000 miles on them,15000 hours generally.They just traveled from well to well,a lot of pto time.The 2010-2012 t800's on the frac crews had bigger engines,some Cummins and a few Cats.They're good trucks if you can find one in decent condition.Southern Truck Sales in Houston sells them for around $50,000.
    The white ones in the chemical division sat around a lot.
    Feedman Thanks this.
  5. AModelCat
    161,291
    With 23k hours its best years are behind it.
    Oil sample, coolant sample, dyno and blowby check will give you a decent idea of engine health.
    Personally I wouldn't even bother spending the time and money to do those tests on something with that many hours on it. If its got decent oil pressure, its not putting compression into the coolant, coolant and oil aren't mixing and its not smoking like a chimney out the oil filler cap when you remove it with the engine running then I'd make an offer based off it needing an overhaul sooner than later.
  6. North Pole Nightmare
    949
    1,836
    Dec 15, 2021
    That's an old good one,but not for sale
  7. abyliks
    3,996
    9,394
    May 2, 2010
    ludlow MA
    Short tractor, bet it rides like a lumber wagon
    Vampire and Big Road Skateboard Thank this.
  8. Big Road Skateboard
    6,644
    37,299
    May 2, 2021
    Best indicator is oil consumprion. Oil samples will be mostly useless without a baseline.
    C12's are cheap and easy to rebuild. If you're staying local and the price is right, maybe.
    Biggest issue with OF equipment, they are rode hard and put up wet, and air filters don't get changed near enough for the environment they work in
    SL3406 and shatteredsquare Thank this.
  9. North Pole Nightmare
    949
    1,836
    Dec 15, 2021
    They ride nice,even on lease roads,but usaully pulling a frac pump or something heavy.
  10. Idaho MTN Driver
    Idaho MTN Driver Bobtail Member
    40
    77
    Jan 22, 2020
    I bought an '05 Halliburton T800 with a C11 a few years ago from auction. 300K miles with 14K hours. My experience:
    1. Everything worked on the truck - they are good on maintenance it appeared.
    2. It was a beautiful truck once cleaned up. Dirty when I bought it and paint was faded, but buffed right back to shiny red.
    3. If it's a typical Halliburton truck, you're going to hate how it's geared. Mine had 5.29's and did almost 2,000 RPM at 60.
    4. I'm guessing it has Neway air ride (or possibly Hendrickson Primaxx). If it's Neway, you will love it.
    5. The C11. If I remember correctly, it is the same block as the C13, but with smaller internals. It wasn't popular because it weighed the same as the C13 with less power, so most people went C13. Mine was set at (I think) 335 horse. I actually thought it was a great engine and ran well. And with the low gears, it had plenty of power. Also, I would not be too worried about blowby on an Acert Cat - it was common.
    I sold the truck but regretted it. I would personally run it until you have a problem.
  11. snowwy
    snowwy Road Train Member
    20,590
    13,308
    Jul 6, 2009
    The alert I once drove got a new piston kit at 200k. Cat was famous for undersized pistons which broke the rings. Causing excessive blowby. And bad oil.
    Construction trucks and pto trucks or tankers will have alot of idle time.
