What material is a fuel tanker trailer made of?
Discussion in 'Hazmat Trucking Forum' started by Richard_Trucking, Jul 17, 2024.
  1. Richard_Trucking
    Richard_Trucking Bobtail Member
    Jul 17, 2024
    Hey everyone,
    I want to understand more about the equipment I'll be working with and ensure I'm handling everything safely and correctly.
    Can anyone here share some insights into the types of materials used for fuel tanker trailers? Are there different materials for different types of fuel? Any tips or advice for a rookie like me would be greatly appreciated!
    Thanks in advance for your help!
    Safe travels,
  3. TNSquire
    TNSquire Medium Load Member
    560
    1,943
    Oct 13, 2016
    Decatur, TN
    Aluminum and stainless steel are what’s they’re built with.
    Non sparking metals.
    Hose fittings and connector fittings are pot metal and brass. Again, non sparing metals.
  4. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    But you can drop a match in them to check to see if there empty.
  5. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    O like the tankers that are plastic with the new vapor release button on the nozzle, self lighting fuel level indicator.
  6. RockinChair
    RockinChair Road Train Member
    5,067
    12,773
    Feb 19, 2012
    CC, TX
    ...once.
  7. TNSquire
    560
    1,943
    Oct 13, 2016
    Decatur, TN
    You sure can.
    Enjoy your express lane trip to Jupiter while you’re at it.
    If you’re lucky, you meet Jesus on the way!
  8. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    No luck to meeting Jesus, it will not be accidental.
  9. TNSquire
    560
    1,943
    Oct 13, 2016
    Decatur, TN
    Correct.
    It’ll be Darwin, assisted by the trailer trash lady at Walmart, leaving her car running while smoking Marlboros pumping $3.86 of gas into her crapbox express with one headlight and smashed door held on with duct tape.
  10. wis bang
    wis bang Road Train Member
    3,386
    3,981
    Jan 12, 2011
    Levittown, PA
    FCMSA's hazardous area has published 'specifications' for all HM trailers divided into different 'SPECS' for various products to be transported under their authorization.
    The SPECS are updated as technology and materials improve and the 'authorized' trailer spec can change, often with the older spec remaining in use until aged out of use.
    Incorrect use usually has semi-disastrous results.
    Caustic Soda [Sodium Hydroxide] eats aluminum.
    Yes the 'story' has some truth, Quadrel Bros. had an aluminum wagon loaded in San Juan and dropped at the pier and the next morning there wasn't much left.
    At Matlack we missed one sub note requiring a lining to use a stainless steel trailer and the product ate it's way out.
    On the other hand the introduction of FRP trailers made lined trailers backhaul-able as it was washable where rubber linings were 'pickled' to one product and always came home empty.
    Fuel loading is specialized and separated from anything else so contamination by something corrosive to the tank is near impossible.
    Biggest danger is 'harry the driving hat' driving over your hoses.
  11. Powder Joints
    7,663
    7,744
    Sep 25, 2007
    Rosamond, SoCal
    But what they ask pertained to fuel trailers, which are normally aluminum. Sometime lined.
