From reading here in forums and personal experience w/ friends getting into the business. We are in a sad place where not even the month or so OTR trainer is much more than a newbie teaching paper work and procedure, vs actual experience and real world 'holy ####' moments. Seems we've created a new breed that doesn't care, and little fellowship/brotherhood that is required.
I'd like this thread to be helpful to newbies, is all. NOT bashing, goal is to educate new drivers to the way we used to do it.
- Get a CB, a cheap one will help you more than this post on how etiquette works... you don't have to speak, just listen.
- Don't pass a 62.5 mph truck w/ 63mph... In a ten hour day you gain 5 mins.<-- hardly worth all the braking some driver make you do for making pissed off driver wait.
- No your place, you have a 70mph rig but can't pull hills... don't make everyone pass you 3,4 times, just know your limitations. (on the second pass give up, your gaining nothing but a headache)
- On 6+ lane, when traffic passes on both sides move to right lane. No matter the speed limit you are impeding traffic.(makes you more a hazard than merging traffic on right)
- Flash/dim your lights when another truck is at a comfortable distance while passing. (dim at night / flash high during day)
Above is/ used to be common sense... everyone was taught this. Now for what they don't teach in fly by training:
- While following another truck, give proper distance... your actions will mimic his but should not depend on front door ever to make decision for you in emergency avoidance.
- Night, fog, rain, hug zipper you only have 2 or less seconds to react w/ break down on shoulder.
- Snow, freezing weather cars are your first warning... they go in ditch first w/ small wheel base. SLOW DOWN.
- Fog lights help ONLY certain situations. Long as they are aimed correctly.
- Run your High beam only when on back roads. (Try this on hwy, you may get blinded @ wrong time... I wanna get aircraft landing light for you morons)
- In heavy traffic watch heads, and speed of other vehicles... When you get eyes for this, you'll know ahead of time what each car wants and anticipate their action well before they signal.
Bad weather:
- In rain, know your wake, cars will try to pass but sit dumbly blinded next to you not knowing if its worse or better in front... sometimes its better to help them along.
- In snow, you always have crazy slow driver that asks for trouble... snow is your friend, its not bad traction, just need some guts to run it. Look for distance between you and right lane... most snow covered states provide rub strip/ aka wake up strip. This is how plow drivers know where to run. If your passing give all the room you can, if your being passed know you still got plenty of room on shoulder.
- Ice, there is no way to make time safely... shut it down.
- Even if all you've ever been told is never use engine brake, or trailer brake... they do work and can be your 'out' in certain situations.
If ever in a slide and your trailer has traction... Grab trailer brake, gently, will get you out of tractor knife.
If in a jab brake situation on greasy road, turn on engine brake... this keeps tractor wheels turning and you in control.
Like to hear more if you got any?
What new drivers should know
Discussion in 'Questions From New Drivers' started by TheDude1969, Aug 10, 2013.
Page 1 of 3
Thanks 4 the info, i hope i get a trainer thats as good at giving advise as you. TRUCK ON !
TheDude1969 Thanks this. -
A lot of good advise there, thanks. Always have used the headlight flashing and the emergency flashers to communicate with drivers. My very first sentence was I wanna be a truck driver, so I have kind of always stayed close to the proffesion and the people in it. Now 40 odd years later I am going to fulfill that goal.
You've got a lot of good info in here Dude, but this one scares me. Usually, if the road is so slippery that your drives have no traction, application of the trailer brakes will just break them loose, as well.
I've been through skid pad training a couple of times and what I learned, and have had to apply a couple of times, is if your tractor is in a skid, what works best is to disengage the clutch so your drives can freewheel, and steer into the skid. The rig will straighten out as the wheels regain traction.
Chase05, DoneYourWay, TheDude1969 and 3 others Thank this. -
All excellent advice which should be printed.
Thanks Dude keep it coming. I can use all the advise you want to give. I was thrown to the wolves after two days orientation I have no real exp. and no trainer but I need this job. I pull over and regroup and ask questions so yeah keep it coming.
Night Prowler and TheDude1969 Thank this. -
Well just cuz there is hills n I'm heavy doing 70moh does not mean I'm follow a 62mph truck.
double yellow and Numb Thank this. -
I should've given more thought b4 post.Phil S and DoneYourWay Thank this. -
Page 1 of 3
