What NOT to do when crossing an ice covered bridge
Discussion in 'Trucking Accidents' started by Lepton1, Feb 10, 2014.
  1. Lepton1
    Lepton1 Road Train Member
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    The first section of this video is worth discussing, an example of how not to drive over an ice covered bridge:
    https://www.youtube.com/watch?v=17aUXZOQ1zg
    Here's my take on what happened to this Swift driver:
    1. It is likely that the driver did not have the inter axle differential engaged.
    2. It is likely the driver did not back off the accelerator as he approached the bridge, to coast through the bridge. Very possibly he may have had cruise control engaged.
    Note that at 01,20 in the video his right side drives have started spinning out to his right. At this point the proper response is to back off the throttle and steer right into the skid. It appears that he never backed off the throttle and any attempt to steer into the skid was too little, too late.
    It's amazing how quickly things can go bad in a situation like this. From the moment the truck began to spin out to being on a fast trajectory toward the median was less than two seconds.
    I recently had a similar situation during an oncoming ice storm in central Texas a couple of weeks ago. I did not have cruise control on and thought I was approaching a bridge in good shape, but I hadn't yet engaged the inter axle differential. As soon as I felt the drives spin out I backed off the accelerator and steered fairly aggressively into the skid. The truck immediately snapped back into straight and true, it was all over in less than a second and I continued driving to the next exit to consider what just happened and get a cup of coffee. After returning to the road I slowed it down and had the inter axle differential engaged for the rest of the day.
    Coast over icy bridges. Light on the throttle, light on the steering wheel.
    bergy, sherlock510, gpsman and 2 others Thank this.
  3. Shaggy
    Shaggy Road Train Member
    3,116
    2,595
    Sep 21, 2006
    FIGMO
    Why would you attempt to Monday Morning Quarterback these wrecks? Dude, it's ICE. Much fun to make fun of Swift. Surprise, It's Ice. Pucker up and brace for impact.
    TruckDuo and Dinomite Thank this.
  4. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Because a professional driver should learn how to drive on ice.... dude.
  5. Shaggy
    3,116
    2,595
    Sep 21, 2006
    FIGMO
    Yeah, we all have studded tires and chains for a unexpected Ice road.:biggrin_2559:
  6. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Studded tires? Really? Please provide a link for studded truck tires. I'm curious.
    Pouring Coal Thanks this.
  7. Shaggy
    3,116
    2,595
    Sep 21, 2006
    FIGMO
    Provide a link when a driver locks in the diff before a unexpected ice covered bridge in Texas. Curious.....
  8. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    Back away from the bong...
    Elvenhome21 Thanks this.
  9. DrivingForceBehindYou
    DrivingForceBehindYou Medium Load Member
    546
    184
    Aug 29, 2012
    ChicagolandOfOpportunity
    Good. Only if your employer finds out what you are doing to his differential lock it might take you a while to find new employment. To engage it you have to come to a complete stop and once on you are not to drive the truck at highway speeds or even close to it
    Shaggy, misterG and jbatmick Thank this.
  10. Shaggy
    3,116
    2,595
    Sep 21, 2006
    FIGMO
    Really, You try too MMQB a swift driver wrecking on ice in texas. Then accuse me of toking up. Funny stuff.
    TruckDuo Thanks this.
  11. Lepton1
    12,647
    25,588
    Nov 23, 2012
    Yukon, OK
    First, you don't have to come to a complete stop to engage the IAD. You can't engage it if your wheels are spinning, but you can engage it when in motion.
    Second, the advise that you can't drive highway speeds with the IAD engaged applies to older technology. Consult your mechanic or dealer for further advise about your particular model.
    Much of the advise about the IAD seems to come from truckers that have been in the business long enough to have grown up with technology that was more fragile.
