It is supposed to be clean, odorless, no holes in the floor etc.
Recently, I had a load of spices. I still smell them despite my effort to eradicate the smell with grounded coffee.
I was not rejected anywhere but felt uneasy at a few pick ups and receivers tbh.
I know from my experience that if you take a recycled grounded plastic, it had better be in well covered totes otherwise you will perpetually end up finding little plastic bits popping up from nowhere - mostly from between the floor boards and looking like little bits of glass which is a no no for food grade trailers.
Another forbidden commodity is recycled cans - smells like #### days after they offload it.
Shredded paper - mess mess mess. Confetti all over the floor.
Never, ever do you dare to load tires....smell and marks hard to wipe off.
I took, foolishly, a load of empty pallets -- scratched the wall boards.
What else?
By the way, I know that the wash out should not be done too often, but how do you guys maintain the floor. Do you sand it once every two years or something like that. Do you paint the wall panels to conceal the scratches? Or is it supposed to lose its food grade status after a few years of usage as a course of nature?
Another question is this; if the shipper attest that your trailer is ok to be loaded, does it mean that in case of a load rejection at receivers due to some trailer "food grade" issues discovered only there, the problem is at the shippers end and not yours? Anyone has experienced anything like that?
What not to load on a Food Grade Trailer.
Discussion in 'Ask An Owner Operator' started by TallJoe, Jul 5, 2017.
If Kraft nose does not think it stinks it's fine.
Everything else is solved by a good washout. The rest of it is taken care of at the shop.
Once in a while we would install a bulkhead and run two temperatures. I had paint in the front and food in the back. That was fun, hazmat too Believe it or not... That food was wrapped 10 times including the pallets.
Spices are nice. McCormick of Hunts Valley comes to mind. I have never had anyone complain of spice in the trailer because out of 5000 little tiny bitty boxes, something for everyone. Shrugs. -
Reefers to me is metal flooring.
Wooden does not do reefer too well. -
Marks on the walls don't make it not be food grade. It's freight. You're going to get marks and scratches on the wall. As long as the trailer is clean no dirt, no spider webs, no trash - you're fine. Stains on the floor don't matter. As long as it doesn't stink and there's no residue. If someone nails scotches to the floor to block pallets after pulling the boards fill those holes (if there are any) with black silicone from underneath the trailer and they'll never reject it for seeing daylight come up through thru the floors. You've got a good list of do not haul stuff. Never ever haul any sort of recycled material that stuff is always filthy. Avoid nursery loads like the plague. When asking details on the load ask "is it a clean load". There should be no hesitation or "uhhhhhh, uhhhhhh" when they answer that question.
TallJoe Thanks this. -
Never haul cow hides omg what a stench it left ..3 washouts including a deodorizer and it still smelled
TallJoe and passingthru69 Thank this. -
Raw plastic for recycling ... generally stored outside. Filled with stagnate water. Frozen offal, 24 hours to deliver, thawed out and stinking by that time.
K Wopper906, TallJoe and DUNE-T Thank this.
