My rims are very rusted and some look bad and I am concerned for safety. I am wondering what you think is better, aluminum or steel for replacement rims. I was quoted about $150 for used aluminum rims. 11R22.5 tires with ten bolts.
The truck is a 2000 Freightliner FLD daycab. 444k miles and runs good and I wanted to get rims that would last a good while, as I am not planning to sell this truck.
What rims on 2000 Freightliner FLD, aluminum or steel
Discussion in 'Flatbed Trucking Forum' started by ichudov, Aug 7, 2018.
I had some steelies sand blasted primed and painted a few years back; think it was $25 per.
I'd powder coat them if I was to do it again. That'd last a lot longer.Oldironfan, BigBob410, ichudov and 1 other person Thank this. -
Buy Aluminum; if you need to save a little$ right now clean/paint 4 of the steel ones and place on the inside, just make sure you use the nylon seal between the two different metals.
If you do clean and paint the steel, use black, stands out less than white against the outer aluminum. -
Aluminum will save a bunch of weight, but other than that, there is no real difference.
Make sure you got enough lug nut engagement?
Sometimes trucks that came with steel wheels have short wheel studs. Aluminum wheels are much thicker.Samuelh, magoo68, Dave_in_AZ and 5 others Thank this. -
I just spent 200.00 plus a bunch of time replacing studs to mount all aluminum wheels on the back axles. My truck had steel inner wheels and the studs were too short. If your truck had steel wheels confirm the studs are long enough to secure an aluminum wheel BEFORE you make a choice.
SteveDave_in_AZ, cke and Tug Toy Thank this. -
I ended up getting new steel on outside and old rims (the better ones) on inside.
To easy to fix bad or short studs, especially if you plan on going all aluminum later.
Don't let that deter you if you're needing an upgrade. -
On an entire truck you're talking a huge difference in weight.
Not to mention, aluminum never rusts to look like hell. If you don't want to polish just leave them gray.... Once in a while have the beacon monkeys hit them with brighter and then they look good again... Super easy.
Steel rims freaking suck imo, they turn into ugly rust pits and add a ton of weight to the truck. You lose the whole way around.
.Bean Jr. Thanks this.
