What should powersteering feel like?
Discussion in 'Questions From New Drivers' started by GiantBeard, Jan 4, 2016.
  1. GiantBeard
    GiantBeard Medium Load Member
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    Hey, I am thinking I'm in a bind here, but I don't really know.
    When I reverse, the powersteering feels like it doesn't want to work. I have to be rolling for the wheel to turn. If I need to make adjustments when stopped, or not rolling fast enough, I have to use both hands and, inch by inch, force the wheel over.
    This makes my alley docking very difficult....
    If it were just that, I would be okay.
    When I have to travel slowly, through an intersection, making left and right turns, and especially on a grade, going up, or down, I lose the power and I have to stop and force it over.
    That's what scares me. It happens randomly, so I'm always on guard. The mechanic didn't think much of it, but I'm about ready to find a new mechanic.
    I've tried the trick about popping into nuetral and revving the engine, and that works, but its not practical, and it doesn't work in gear, or with the clutch.
    Not just wussing out, am I?
    If anyone's got a smart idea, or a suggestion, I need an informed opinion to make headway with a repair request.
  3. samton
    samton Light Load Member
    63
    15
    Dec 31, 2015
    It should be effort less. Check fluid. Could be the filter or bad pump.
    GiantBeard Thanks this.
  4. GiantBeard
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    The fluid is always good. I've got a little seepage around the hoses, but not enough to drop the fluid below the add line, and its been 3 months since my last service.
    Effortless was how I remember the driving school. This is kind of a workout.
  5. mountaingote
    mountaingote Road Train Member
    2,026
    7,916
    Sep 22, 2012
    Probably a pump issue. If it doesn't pump any fluid, it will feel like manual.
    Mudguppy and GiantBeard Thank this.
  6. mr truckdriver
    mr truckdriver Light Load Member
    286
    178
    Mar 2, 2008
    ft myers fl
    Check the power steering belt if it is loose it will be slipping and not pumping at full capacity.Or the pump is taking a dump on you
  7. GiantBeard
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    All the belts feel tight. Just a little bit of play. When I push on them, the tension pulley (is that the right word?) moves a bit. This is my first experience with trucks, is that normal? I'd say if I had to count the tensioner moving, when I press on the belt, there's well over an inch of play.
  8. sawmill
    sawmill Road Train Member
    3,703
    68,689
    May 29, 2015
    Evanston, WY
    What engine do you have? The power steering pump is usually gear driven. There is also usually a filter inside the power steering fluid reservoir and most people overlook changing it.
    baha and GiantBeard Thank this.
  9. GiantBeard
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    I've got a Cummins ISX 400hp. The boss bought this thing used, 500k+, from Arrow truck sales.
    In other words, from what I've been reading, it was a fleet truck that was due for all the major maintenance.
  10. sawmill
    3,703
    68,689
    May 29, 2015
    Evanston, WY
    Yeah I would start with the filter, it's probably never been changed.
  11. GiantBeard
    323
    343
    Oct 16, 2015
    Petaluma/Indio, CA
    Thanks! As much as I know I need the exercise, I'll start from there and hopefully I dont have to replace anything expensive, which would assuredly be a result of "how you drive the truck". o_O
    baha Thanks this.
