What size airline for tires?
Discussion in 'Ask An Owner Operator' started by Dino soar, May 18, 2020.
  1. Dino soar
    Dino soar Road Train Member
    4,791
    26,882
    Dec 8, 2017
    I have a glad hand that I can use to run airline to fill tires.
    I'm wondering if I use a line that is 1/2 inch if that would be better than using a 3/8.
    The half inch line will definitely give better flow but if it's going down to a quarter inch air Chuck I'm not sure if that's better.
    What do you guys think and what do you use?
  3. buddyd157
    buddyd157 Road Train Member
    13,576
    34,885
    May 25, 2017
    under a shade tree
    sheesh, i gotta read slower, when i'm munching on corn chips.
    i thought your title read, "what size airline tires"...(didn't see the "for")
    i'm thinking like, "dude, stick to trucks, will ya"?
    and just an airline. i cannot recall what i had, musta been a 1/2 though, or it could have been a 3/8, what ever i bought at the Pilot back then.
    Bean Jr. Thanks this.
  4. Zues
    Zues Bobtail Member
    47
    26
    Apr 22, 2020
    Lol I use a 3/8 I decided because of size space not flow jmo
    Dino soar Thanks this.
  5. SmallPackage
    5,535
    17,632
    Dec 20, 2019
    Marion Texas
    If the compressor can handle it the 1/2 will give you more volume of air and will help air up tires faster and run 3/4” or 1” impacts if needed. Psi stays the same but gives you more air movement at the pressure over a 3/8. Also the longer the hose the bigger the diameter is better.
    Bean Jr. and Dino soar Thank this.
  6. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    Are you thinking something to store on the truck, I would go 3/8, takes up a lot less space and is much more flexible. If you're keeping it at a shop, 1/2 inch gets the job done faster, not necessary though.
  7. Dino soar
    4,791
    26,882
    Dec 8, 2017
    Well I'm looking for something to carry on the truck and your right 3/8 is definitely more portable.
    But I have heard people complain that it takes a long time to pump the tire up and since I'm buying a hose either way I'm wondering if I should just get the half inch and forget it.
    If the diameter of the hose really is going to help over 50', maybe the half inch is better?
  8. Dino soar
    4,791
    26,882
    Dec 8, 2017
    Can the compressor handle it? It's a regular freightliner tractor trailer that runs at about 120 PSI.
    I can't do it immediately but I was wondering if I could find a good sized air tank if it would help to mount a large tank on the trailer for volume.
    I would put an on off valve just so that it's isolated from the rest of the system until I need more of a volume for whatever work I'm doing with air.
    More volume I would think would help. Does that make sense?
  9. Rubber duck kw
    6,092
    17,686
    Dec 9, 2017
    I'd hate to try to find some place to hide 50 foot of 1/2 inch air hose on my truck. I've put tires on the wheels with 3/8 line, that's running a 3/4 impact, and 110 psi in the tires, with a compressor that makes 130 psi max. That's actually what takes so long to air up tires, your comprsseor has to be running constantly to get you enough pressure to fully air up your tires.
  10. SmallPackage
    5,535
    17,632
    Dec 20, 2019
    Marion Texas
    What I meant by if the compressor can handle it is what is it’s cfm capability. If it is the bare minimum to just keep the rig aired up and running you may be waiting a long time to get air into a tire. They are all capable of building pressure to 140 psi but it’s the amount of time and work it takes the compressor to do it. Also figure the more the compressor has to run to do it the hotter the air you are putting into the tires or air tools is going to be.
  11. SmallPackage
    5,535
    17,632
    Dec 20, 2019
    Marion Texas
    You may have to idle the truck up a little if it takes a long time for the compressor to build at low idle. It’s all doable. Just get what works for you.
