What size are these rears
Discussion in 'Ask An Owner Operator' started by 1989 Pete, Jul 19, 2009.
Read the truck info sticker, probably in the door jam.
There should be some sort of a plate on the pots that will tell you what the rears are or call dealership and give vin # and they should be able to tell you what it came out with. But that is not a guarantee as to that`s exactly what gears are inside as they could have been changed.
Get under the truck and look at the axle housing. If you are facing the rear of the truck and looking up at the housing, there should be a metal tag spot welded to the housing on the drivers side close to where the differential goes in. There should be some numbers on there you can use to ID the rear ends with.
Ok I was trying to see what is rating of axle pounds are the suspension set up are they 40k or 44...............That's what itnitially I was trying ask
get your vin # and call a dealer they can give you all the specs for that truck
if you ID the axles you wil know what they are rated for. but I'm with the others. call the dealer with the VIN
Ok thanks will do!!!!
