What size Inverter do I need
Discussion in 'Questions From New Drivers' started by WhyDriveTruck, Jul 21, 2015.
  1. WhyDriveTruck
    WhyDriveTruck Light Load Member
    272
    60
    Sep 1, 2013
    Detroit
    got a 2012 Pete need to buy a inverter but I have no clue what size I need to buy please advise . I was thinking a 1000 watt was enough , what do you guys think
  3. otherhalftw
    otherhalftw R.I.P.
    13,081
    45,332
    Nov 18, 2008
    CA...gold discovery foothills
    Just couldn't resist: LOL
    Size matters! Depends on if it is a male or female doing the buying!;)
    HorseShoe Thanks this.
  4. HorseShoe
    HorseShoe Road Train Member
    1,494
    2,779
    Jun 29, 2015
    1500-2500 depending on your budget
  5. Skate-Board
    Skate-Board Road Train Member
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    Ya, 2,000 would cover you if your going to run a Mr. Coffee. If you are running something big like a Mr. Coffee you should run the trucks engine at the same time.
  6. White Dog
    White Dog Road Train Member
    3,161
    3,807
    Feb 11, 2008
    Iowa
    It depends on what you plan to run off of it. I have never had a microwave oven...so can't tell you what they draw. But Skate-Board must have a HUGE coffee maker, because my little 4 cup Mr. Coffee coffee maker draws EXACTALLY 850 watts at it's peak during brewing (it has a LED read-out), and my 1,100 watt inverter does just fine with or without the truck running.
    The trick is to keep the power cables from batteries to inverter as short as possible...the more direct current the inverter can draw from the batteries, the less the inverter has to work.
  7. Skate-Board
    3,801
    3,996
    Aug 9, 2014
    Merrimack, NH
    I have the grown up model, not the Nancy one
  8. White Dog
    3,161
    3,807
    Feb 11, 2008
    Iowa
    LOL! Ok. I bet you have one of those $450.00 "grown up model" GPS units that get's you to the same place, on the same roads as my Nancy $134.00 GPS too?
    P.S.- Yes I know you are joking...as am I:p
  9. tlalokay
    tlalokay Medium Load Member
    473
    773
    Jun 3, 2014
    El Paso, TX
    If you're going to run a microwave and fridge then get a minimum inverter capacity of 1800 watts, but 2000 is better. Also, you'll probably want to unplug the fridge while you're running the microwave.
    The peak wattage of the appliances you run is just as important as the max capacity of the inverter.
    And as the other poster said, get a direct line to the battery- which may require some drilling on your part.
  10. Ubu
    Ubu Road Train Member
    1,252
    1,178
    Aug 25, 2012
    Rumored to be somewhere
    How large of a bucket do I need?
    It’s a pointless question without including more information. You will need a larger inverter if you are running a fridge and/or microwave then you would if you do not have one or the other (or ether).
    Just add up the wattage of all items that you NEED to use at the same time and add 10% - 15% to that number and you will have your answer. I say NEED as some items can be switched off while running another item for instance a coffee pot could be turned off while running a microwave and then switched back on when you are done with the microwave.
    Oldman49 Thanks this.
  11. cerberus63
    cerberus63 Light Load Member
    165
    118
    May 24, 2015
    Gates of Hades
    And has already been stated run as short of wiring from the battery to the inverter and as large or heavy gauge wire as you can (less amperage loss).
