What the H-E-Double hockey sticks are these???
Discussion in 'Peterbilt Forum' started by DocHoof, Apr 23, 2015.
  1. DocHoof
    DocHoof Light Load Member
    160
    81
    Sep 2, 2014
    OK, can't post pics for some reason...I know what is causing me heartburn, but don't know what they are called. Best I can figure is "bushings"...
    2000 Pete 379. Hood is loose when down and bangs and vibrates my poor pooch to death. The bumpers the hood rests on that are mounted to the firewall squeak and are more irritating than my ex-wife's nagging voice. The lower portion, there are some flared guides mounted to the firewall that the "bushings" mounted to the hood go into and are adjustable in, out, up and down. It appears the "bushings" may have, at one time, been made out of a rubber but are now just the bolts. So, the parts I need names for are the "bushings" mounted to the hood, and the "bumper" the hood rests on when down. Hopefully I've provided enough info someone can finger out what I'm looking to replace.
  3. boneebone
    boneebone Road Train Member
    2,296
    2,367
    Mar 13, 2009
    If you go to the Peterbilt Stealership with the last six numbers of your VIN, they can find and order all the parts you need.
  4. wore out
    wore out Numbered Classic
    15,995
    193,690
    Jun 5, 2013
    CHASIN THE DEVIL'S HERD
    Get on EBay look in the peterbilt parts. They will have pics and they are all pretty much the same.
  5. FLATBED
    FLATBED Road Train Member
  6. Arkansas
    Arkansas Medium Load Member
    514
    668
    Dec 20, 2014
    LA- Lower Arkansas
    Better make sure that hood isn't rubbing against your air to air also. It'll rub a hole in it if it is.
  7. icsheeple
    icsheeple Trailing the Herd
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Are you talking about these hood holders??
    They do need periodic greasing. And when you replace them, don't tighten them all the way down at first. Set the hood down on them to align them, then torque down.
    blairandgretchen Thanks this.
  8. ‘Olhand
    ‘Olhand Cantankerous Crusty
    6,701
    16,326
    Jan 18, 2011
    They are hood bushings.....the top mounts....spray w/white lithium quiets them right down...the rollers when proper are covered in rubber....and I spray them same way...coat it all white...every couple of weeks....no noise...:)
  9. icsheeple
    2,548
    2,552
    Nov 1, 2013
    Kansas City, KS
    Why didnt I think of that. I bought a spray can of white lithium and keep forgetting about it, but I ended up slathering the cones with grease from my gun and making a mess.
  10. FLATBED
    Silicone spray or rubber dressing spray does a good job as well and not as messy as the grease
    icsheeple Thanks this.
  11. Luwi67
    Luwi67 Heavy Load Member
    747
    484
    Oct 24, 2012
    Long island
    Friend of mine bonded a small square of indoor/outdoor carpet to each hoodrest bumper, no more noise and no mess.
    pearcetrucking Thanks this.
