What time of day do you drive?
Discussion in 'Questions From New Drivers' started by Texace146, Oct 5, 2013.
  1. Texace146
    Texace146 Bobtail Member
    11
    Sep 27, 2013
    Houston, TX
    I'm familiar with the 14 hour on-duty/11 hour driving rule. This question is different.
    Do companies require you to drive at specific hours of the day? For example, ABC Transportation says, "You must drive from 06:00 to 17:30 (30 min. break included) and blah blah blah... or do companies not care what time of day you drive as long as you get there on time?
    Reason I ask this is because I've been a night owl since I was about 13 years old. (Heck, look at the time stamp of this post.) If I could "have my cake and eat it too," I'd wake up at like, 15:00, take off at about 17:00 (if I'm not near a big city near rush hour) and drive until about 05:00. Less cars on the road at night, I'm more awake, and by the time I'm ready to turn in, I'd snatch a spot vacated by some early birds.
    Is this doable, or would I have to adjust to being an early bird and driving from about 06-07:00 to about 18-19:00? Reason my clock is so screwed up is that I've been in retail all my working life, and it would suck to close, then open, so I'd just request all closing shifts (which no one else wanted) and I've gotten used to waking up at 12, coming in from 15-23:00 and staying up until 4am. If need be, I could adjust to any other "shift" as long as I get into some kind of consistent routine. Sure, there'll be days where I'll have to make an 8am appointment or a 3am appointment, but that's expected.
    What are your thoughts on this? What time of day do y'all drive? Heck, are there even any required hours of operation either by corporate or government regulation? (Wouldn't surprise me; everything else is regulated. lol)
  3. Chinatown
    Chinatown Road Train Member
    75,730
    173,518
    Aug 28, 2011
    Henderson, NV & Orient
    Many of us prefer driving at night when there's less traffic and sun glare. There's more solitude and comfort at night with the dash lights low, a hot thermos of coffee and XM radio.
    There are no set rules; just depends on your appointment times. On long haul runs cross country, it's easier to find a decent parking spot for the sleep/break periods during the day. Run at night then pull into the truckstops at daylight when most drivers are leaving and then there's plenty of parking.
    Reycer, Texace146, Boy Howdey and 2 others Thank this.
  4. jdmiller8265
    jdmiller8265 Bobtail Member
    37
    29
    Apr 14, 2013
    Chinatown said it right. Night is the best time. Take Nashville, Tn for example. In the it could take 1 hour to get through going N up I65. But at night maybe 15 min. No company that I know forces day driving.
    Chinatown Thanks this.
  5. Chinatown
    75,730
    173,518
    Aug 28, 2011
    Nashville can be rough. Maybe some century they will finish the 840 bypass. The Northern loop will probably never be built due to costs due to terrain. If you're headed South on I-65 to I-40 West during rush hour, take the Briley Parkway West route. It's just like an interstate with one traffic light at the entrance to I-40 West. There's also a Pilot Truck Stop on that route.
    Do the reverse to bypass Nashville to I-65 North.
  6. 8thnote
    8thnote Road Train Member
    1,980
    3,687
    Aug 12, 2013
    Chattanooga, TN
    The load dictates the hours that you drive. That's one aspect that can make trucking very tough for some. You may have to switch from a day-time shift to graveyard shift and back again, all within the course of a week. Just depends on pick up and delivery times. You've gotta learn to rest whenever you can so youre ready to service the customers at their convenience. Circadian rhythms? What's that.
    coastie Thanks this.
  7. coastie
    coastie Road Train Member
    II always tried to run at night but times you need to run in the day time. So you must remain flexible as much as you can. I would work it however I leave out of the truck stop at midnight and normally parked by 10 or 11AM but no later than 2PM Unless I had a late afternoon appointment it worked great. Then I would have to adjust. But not always able to do so. As the Gunny said in Heart Break Ridge, Adapt and improvise.
  8. TruckDuo
    TruckDuo Road Train Member
    6,394
    9,373
    Oct 21, 2012
    Chicago, IL
    If you team, you can always be driving at night.
    The other pro to this is that your teammate would deal pretty much the shipper/receivers since most loads are due during the day. All you would do is drive.
  9. white wolf
    white wolf Light Load Member
    287
    131
    Jul 1, 2013
    minneeessoooota
    Well the only thing to keep in mind is the new reset rules 34 hour reset says you cant reset between 1am and 5am thing havent looked at it for a month but may be a issue
  10. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    Companies will normally want you to drive when ever you need to whether night or day depending on the load, I try and stay driving during the day time, some drivers do like the night time better, but not all, that will be your choice, try both figure what suit you better, most loads you will get as a company driver will allow you to drive almost when you feel most comfortable, If you try the night time, just remember that is when Animal activity is higher, Less visibility equals less response time, but, on the plus, lots of chicken coops are closed at night, but if your attentive to your truck/trailer, and paper work, there's not much issue then, /good luck, and stay safe
    pattyj and JR80 Thank this.
  11. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    I prefer days.This morning it was 3:45.But like crzyjarmins says,it depends on the load which can really screw your sleeping schedule.Dispatchers will try and work with you once you've been on their board long enough and know what hrs are most productive for you.
