What to do?!!! Cummins engine keeps shutting off!
Discussion in 'Heavy Duty Diesel Truck Mechanics Forum' started by PeteV80, Nov 1, 2018.
  1. PeteV80
    PeteV80 Bobtail Member
    8
    Nov 1, 2018
    Hi everyone, I have a 2008 KW T800 with a cummins isx500 engine 500hp used for heavy haul. The truck was running great but a few days ago it shut off while running. We noticed that when the temperature reached 200 on the gauge it shut off before the fan clutch kicked in. We checked the wiring for the fan clutch and everything seems fine. We connected the computer and it gave an active code for the After treatment doser. Replaced it with a new one, turned on fine but when it reached a temperature of 200 it shut off again before the fan turned on. I was told that the engine is protecting itself which is why its shutting off and that's fine and dandy but why is it shutting off? Has anyone had this problem? What could it be? Any help appreciated. Thanks!
  3. KB3MMX
    KB3MMX Road Train Member
    3,069
    2,589
    Dec 29, 2014
    Orrstown, PA
    Can you turn on the fan at all ?
  4. PeteV80
    8
    Nov 1, 2018
    Yeah seems to be working fine.
  5. PeteV80
    8
    Nov 1, 2018
    It's supposed to turn on by itself at a temperature of 210 and it wont even reach to that point.
  6. McMahons Trucking
    McMahons Trucking Light Load Member
    274
    119
    Jul 4, 2018
    Could it be a faulty temp sensor?
  7. PeteV80
    8
    Nov 1, 2018
    Would've the computer have picked that up when it was connected?
  8. McMahons Trucking
    274
    119
    Jul 4, 2018
    Im not sure. Do you knoe the actual temperature of the engine?
  9. PeteV80
    8
    Nov 1, 2018
    When the engine is running and the temp starts to increase as soon as it reaches 200 it begins to shut off. The fan is supposed to turn when it reaches 210 but before it even gets there the engine shuts off. The guys at rush hooked up the computer and it said it was the doser so I purchased a new one and replaced it but that didnt work. I didnt want rush to replace it cause they are pricey so I hired another mechanic to do it thinking that would be it but apparently its not. So when the engine cools down it'll turn on again but once it starts to heat up same problem occurs.
  10. Goodysnap
    Goodysnap Road Train Member
    3,716
    9,022
    Jul 12, 2017
    If the engine is programmed to shutdown mode it will under the conditions it's being told too. Your condition sounds very repeatable which is good. With a computer and Insite connected capable hands should be able to sort this out.
    First see how it's set up. Check low coolant, coolant temp, low oil pressure, high oil pressure, oil temp, Exhaust temp for starters. Remember the engine may not actually have a problem but the ecm sees that there is.
    For troubleshooting sake you can take it out of shutdown mode to see if it still does it?
  11. PeteV80
    8
    Nov 1, 2018
    Just had another technician hook up the computer for a diagnosis now its saying "ECU power output supply voltage #1. Data erratic, intermittent or incorrect." So now it's the computer? Going crazy!
