What to do when no scales are available?
Discussion in 'Questions From New Drivers' started by Ganian, Apr 28, 2017.
  1. Ganian
    Ganian Bobtail Member
    Last night I picked up my first ever load. It was heavier than anything I hauled during training. The original BOL said 44,000 lbs. They asked if I could haul it and offered to drop 2 pallets if it was to heavy. I asked them to. After I was loaded i looked for a scale near by to check axel weight. There was no scale near-by and I would have to go thru a way station before I got to a scale. What is the best thing to do in a situation like that? I left and hoped for the best and was legal but I don't want to do that if I don't need to.
  3. Nukem
    Nukem Road Train Member
    1,237
    1,447
    May 11, 2014
    You'll have no choice but to hope for the best if there is no scale around. If I pick up a load from somewhere that I have never been and I am unsure of how they load or the way it looks. I look for another driver to see if they; 1. have been here before and ask how they load and 2. get his advise about where to put the tandems if my load doesn't look right. I'll even ask the loader (if I can) to see whjat the standard load plan is for them...
    I also scale as soon as I can even if the scalehouse give me the green, so I can verify I'm not in for a rough ride...
    It never hurts to get a second opinion...
  4. pattyj
    pattyj Road Train Member
    22,474
    20,137
    Jul 19, 2008
    Sioux City,ia
    Next truckstop buy a pocket truckstop guide.It list all the truckstops with a scale and make sure you have a truckers atlas that lists all the weigh stations .Sometimes you may have to go the opposite direction a few miles to the nearest truckstop.While you get loaded see where the nearest truckstop and weigh station is.If you're still worried because there's no place nearby to weigh your load then look on your atlas for an alternate route just till you get past the scale then get back on the interstate.
  5. 28
    28 Medium Load Member
    690
    44,437
    Sep 17, 2015
    Most truck GPS's have a selection to locate the nearest scale or truck stop
  6. Braylean
    Braylean Light Load Member
    203
    120
    Sep 10, 2013
    Personally I always try to put the axles under the last two skids in the trailer or just forward if possible. You can guarantee that if the skids don't come back far enough to get the axles under the load and it's heavy then they are at least going to have to be slid all the way forward but most likely your going too be over on your drives and your going to have to make them reload it and string the load down the trailer better. This will be done by having two skids side by side in the nose then one in the center then two more side by side and so on however many time it takes to get the load most of the way to the back of the trailer. I know this is long but hopefully it's useful. Other than this the advice above is all great advice.
  7. Ganian
    Thank you for the good advice. It's a bit nerve racking for my first load.
  8. STexan
    STexan Road Train Member
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    When you go to a new job and get your own truck, you should weigh your truck/trailer while empty but full of fuel, tire chains, and all your personal gear. This way you know what your capable of taking on. Keep this number in a safe place where it can be referred to later until it's memorized.
    Now, you also need to know that very often shippers will throw out a weight that DOES NOT include the weight of pallets. When unsure, ask. I use 75 pounds per pallet, others use 100#s for safe measure.
    Finally, shippers estimated weights are sometimes very close, perhaps mostly within 500 pounds (excluding produce, scrap, and other highly variable weight products).
    Until you gain more experience guesstimating axle and gross weight, when you know it's probably more than about 35k load, don't assume too much until you can weigh. (If/when you can)
    SoulScream84 and DoneYourWay Thank this.
  9. Cornbinder_King
    Cornbinder_King Light Load Member
    176
    237
    Mar 29, 2017
    CAT has a smartphone app that has all the scales information.
    It has saved me from at least one OW.
  10. HopeOverMope
    HopeOverMope Road Train Member
    1,801
    3,210
    Feb 25, 2016
    I-20 LOUISIANA
    Heard one driver tell me years ago that he never scales loads, he simply checks the bulge on his tires, from the drive tires to the trailer tires: makes sure they all have the same amount of bulge
    He showed a page long math problem diagram of how it works every time
    Stonehjl and Lumper Humper Thank this.
  11. STexan
    14,963
    29,154
    Oct 3, 2011
    Longview, TX
    Another reason to use the Cat Scale Locator App is that it is sort of a handy-dandy universal truck stop locator app, too if you don't have one of the other apps.
    I also recommend the Cat Scale "weigh my truck" app. Saves you from having to go inside to pay which is helpful when the truck stop is a super busy complete cluster ## and your set up with your company to put Scale charges on the fuel card and don't necessarily need the paper Scale ticket.
