What to look for: Buying 1st trailer
Discussion in 'Ask An Owner Operator' started by Rich_Trucking, Mar 10, 2013.
  1. Rich_Trucking
    Rich_Trucking Light Load Member
    248
    21
    Dec 11, 2012
    Hello EVERBODY,
    I'm located near Sac, Ca and Im looking to buy my first trailer
    Im looking to get a dryvan
    I really don't want to get screwed so I want to make sure I do my research before looking for one.
    I seen some posted for 6-7 k. Really cheap!!!
    What should I look for/at when buying from a private seller?
    What make/ yr I should get? Does the yr really matter.
    I dont want to pay more than 10k.
    How much do the plates normally cost?
    Any tips and advice will be appreciated
    thanks
  3. head_above_water
    head_above_water Bobtail Member
    35
    8
    Nov 30, 2012
    stone mountain, ga
    Honestly rich I was wondering the same thing....I talked to a guy at a T.A. and got a list of some of the things they look for on d.o.t. inspections...maybe you could do the same...as for plates I have no idea.....I will post the list of things the guy at the T.A. said a little later when I do my dvir later...but if you find out anything please let me know and I will do the same..
  4. critters
    critters <b>Late For Dinner</b>
    1,444
    2,440
    Jul 16, 2011
    traverse city,MI
    look at every thing, floor condition,doors,hinges,hubs for leaks,look
    for fork truck damage,wire harness and air line chaffing underneath,suspension for any damage.
  5. 59BROCKWAY
    59BROCKWAY Light Load Member
    168
    68
    Jun 22, 2012
    Northeast
    Make sure if possible to slide tandems with your tractor, also look at the pins and general condition of the sliding an locking mechanism. Look underneath for rotted beams. Wiring should be looked at the same time your tractors hooked to make sure all the lights work. Look at the drums and lining. Air brake chambers should not have rot holes. Tires should be good. Doors should latch easily. Make sure landing gear works well in both settings. Look inside make sure trailer does not leak. Many places will turn you away if your trailer has holes. If possible wet it down. Take a look at the general condition overall. It's better to spend a little more than have a headache. Good luck with your purchase.
  6. tomkatrose
    tomkatrose Light Load Member
    224
    161
    Oct 22, 2010
    Los Angeles, CA
    Rich, don't bottom feed on your trailer too much or you'll spend the difference in repairs. Trailers in the 6 to 7K range are usually pretty worn out. Agree with the other comments here. Plates in CA are cheap but it's the sales tax you have to pay for the purchase.
    BTW, I'm thinking of selling my 2004 Great Dane Classic. It's in great shape, recently been gone through by Utility Trailer in Fontana, relatively new tires, no leaks, no holes, etc. If you're ever in the L.A. area, you're welcome to look at it although it'll be around $12K which is more than you said you're looking to spend. It's really well maintained.
  7. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    walk down the side of the trailer and look at your rivets. If they look to be galling, walk away. Means the floor joists are loose.
    Sight down the side of the trailer. Should be smooth and straight.
    I KNOW where there is a REALLY clean great dane dry van in MN in Albert Lea. I just traded mine for a reefer. I originally paid $7500 for it. I was looking at brakes for the biggest expense on that trailer. I got it at Trailer Source in Orting WA. nice guys.
    http://www.trailersource.net/default.htm
  8. Blind Driver
    Blind Driver Road Train Member
    3,081
    1,406
    Aug 7, 2006
    New Albany, IN
    Don't forget the test drive. Make sure it doesn't pull.
    The shocks shouldn't be rusted. Many companies don't change the trailer shocks.
    Look at all the bushings. Nothing should be dry rotted.
    Look up at the fifth wheel plate. There shouldn't be any excessive wear nor gouges.
    If it has good brake shoes, that doesn't mean the drum are any good.
    Check the roof for leaks. Sometimes the floor will be stained.
  9. thelushlarry
    thelushlarry Road Train Member
    3,023
    8,999
    Jan 9, 2012
    glasgow ky
    Get inside of it with the sun shining and have someone you trust close the doors!!
    Sly Fox Thanks this.
