what to spray on my windshield when frozen
Discussion in 'Questions From New Drivers' started by 4noReason, Oct 23, 2013.
Page 1 of 5
I don't know of anything other than interior heat to effectively deal with snow and/or ice on exterior glass surfaces. Try and park headed towards the southeast when you dealing with a system with winds coming from north/west. In the south during freezing rain setups some lock deicer may come in handy but won't do anything to help break the ice around the door jam if you're outside trying to get in.
Depends on when its freezing. If you are driving down the road with a dry snow coming down, just turn your defroster off so the snow doesn't melt on you windshield and then freeze. It will stay frozen and then just be blown or wiped off.
If you wake up to ice on the windshield let the defroster melt the ice loose and push it off with a broom.
If its a wet snow or rain that is freezing a good washer solution will help, but sooner or later you will have to stop and knock the ice off your wipers.
That is of course if you haven't bought a set of heated wiper blades. -
Some people have high praises for RainX. I found it a PITA and very difficult to properly apply and did very little to deal with rain/snow over the longer term. Works great for rain the first little while, then it's like you wasted your time, and your money.
blairandgretchen, mustang970 and thecleaninglady Thank this.
MZdanowicz, blairandgretchen and luvtotruck Thank this.
Do they do enough to also transfer heat through to keep the wiper blades mostly pliable during a heavy snow event? I'm having a hard time finding them at whitney. What are they called exactly?
MZdanowicz Thanks this. -
Be cautious when appling excessive heat to your windshield. Heating your windshield and then having a heavy spray of snow or icy water hit it will leave you with a nice crack acrossed it and you having to get it replaced.
Lady K Thanks this.
Put your heat on def on high and pull your visior down close to the window so it holds the heat in. It works for freezing rain purdy good.
MZdanowicz and J_FROG Thank this.
Page 1 of 5
