What tools should every trucker carry?
Discussion in 'Questions From New Drivers' started by Sean_Memphis, Mar 2, 2015.
  1. Sean_Memphis
    Sean_Memphis Light Load Member
    289
    44
    Oct 9, 2014
    Memphis, TN
    What tools should every trucker carry (tire knocker, tire pressure gauge, etc)??
  3. Captain Canuck
    Captain Canuck "Captain of the Ship"
    854
    541
    Apr 7, 2007
    Woodstock, NB, Canada
    Pliers, vice grips, flat, phillips, and robertson screwdrivers, hammer, crowbar, small socket set, wire cutters, strippers, electrical tape, duct tape, bolt cutters, tire pressure gauge, gladhand air line with tire chuck, funnel, electrical test light, just off the top of my head.
    unloader, Freddy57, Sean_Reno and 2 others Thank this.
  4. XCELERATIONRULES
    XCELERATIONRULES Medium Load Member
    492
    492
    Dec 29, 2014
    Desert eagle...works great as a hammer!:smt071
    nshore harleyguy and Sean_Reno Thank this.
  5. freebirdusa
    freebirdusa Light Load Member
    271
    133
    Oct 21, 2014
    Thomaston ga
    Zip ties. The Desert Eagle isn't a bad suggestion also.
    Sean_Reno Thanks this.
  6. Starboyjim
    Starboyjim Road Train Member
    2,039
    1,425
    Dec 10, 2011
    Weed, CA
    What Canuck said, plus: spare headlight/tail light/license plate/marker bulbs. Needle nose pliers, regular pliers, large slipjoint pliers, 24" bolt cutter, clear plastic tape, (placards) 26oz flat claw hammer (pulls nails better'n anything else, doubles as tire thumper) Torx socket set, zip ties, 4" and 8", vise grips for reluctant tandem pin locks, spare 2 and 3 element plugs, good flashlight, (RayoVac at THD works for me) new spare windshield wiper blade, (Not the old one you took off last summer) some cargo straps/load locks, and a tapered block of 6x6 to raise drives for inflation of flat. More, this is only a partial listing. Also, van or flat have similar requirements on some stuff, but flatbed takes more love.
  7. crzyjarmans
    crzyjarmans Road Train Member
    3,314
    2,441
    Jun 9, 2010
    Home
    The tools cpt Canuck suggested should do just fine, but I'd check with the company on policies when doing repairs to the truck, Now the other suggestion I also think is a good idea! Maybe not quite that particular one, but I wouldn't discuss that with the the company
  8. plow boy
    plow boy Bobtail Member
    36
    35
    Jun 17, 2014
    Get you some extra belts and maybe an air to air hose i. If you ever pop one you will know what I mean. Carry an extra air to air clamp or two . Filter wrench and a couple extra fuel filters. Can of brake cleaner, starting fluid(pop out a flat in a pinch), power steering fluid ( put in your fuel filter to crank her up after a changer),antifreeze, water, fuel treatment, 20 ton hydralic jack, some wood 4x4 blocks. 6x6 wood blocks, a hand tool to tighten your wheel lug nuts in a have to case, cheater pipe, extra pig tail, put you a pair or two of extra gloves in there. One good leather pair and one for cold weather. A milk crate or two works good to keep it all together. The toolbox under the door on a W 9 will hold two or three milk crates of stuff and you can pull the whole crate out get what you need and slide it back in with no problems. Yeah and get you a big chain and throw somewhere and have a tow hook. You will be needin it at some point. The other stuff like electrical wire , tools , etc, will depend on how skillful you are at mechanical repair and trouble shooting. We carried at least two small toolboxes in the sidebox. Yeah and dont forget a bottle of air brake antifreeze for frozen brake lines. In a pinch we have used regular old rubbing alcohol.
    HellStomper116 Thanks this.
  9. Ebola Guy
    Ebola Guy Heavy Load Member
    977
    789
    Oct 11, 2009
    Manitowoc, WI
    Hold on, hold on, hold on here a second...... is the OP and owner or a company driver? If he is a company driver, then a cell phone, a cord, and 12v adapter to keep it charged.
  10. Studebaker Hawk
    Studebaker Hawk Road Train Member
    3,007
    9,779
    Oct 18, 2010
    NW Indiana
    I have seen guys with an 8' drom box on their tractor, full of all tools and most spare parts to do everything but do an inframe major. The key is PM. If you are carrying too many tools and too many parts, you should either get rid of the tractor or spend a little time on "scheduled" maintenance, instead of roadside demonstrations.
  11. FLATBED
    FLATBED Road Train Member
    robertson screwdrivers :biggrin_25524: must be a Canadian thing ( and YES I know what they are also the HISTORY behind them )
