What type of repairs have you done on the road?
Discussion in 'Questions From New Drivers' started by Pmracing, Sep 5, 2011.
  1. Pmracing
    Pmracing Road Train Member
    6,354
    3,178
    Jan 28, 2011
    Arlington Heights, IL
    I have made a few but nothing ingenious. I thought sharing would be good for us new drivers who might not realize what we can do with duct tape or a screwdriver....
    Edited to add:
    Changing a headlight is pretty easy, in the only truck I have driven. The headlight is in a socket that just twists and comes right out. If it does not twist all the way, then unclip the wire harness and that will free it up to twist easier. Remember if it is a halogen, do not touch the glass with your skin. SOmething about the skin oils will make it burn out real fast.
    Buy two when one goes. Often the other will burn out shortly after. Changing it yourself can save you four hours in line at the TA service waiting on some guy getting brakes done!
    Mikeeee
  3. lonewolf4ad
    lonewolf4ad Road Train Member
    7,743
    7,773
    Nov 4, 2008
    Displaced to Colorado
    I built a 53 foot trailer out of an old fridge, some bamboo sticks, and 2 rust wagon wheels just like Macgyvre.
    Ok seriously most I did was fixing the lights on a trailer.
    NewNashGuy Thanks this.
  4. Diesel Dave
    8,735
    25,090
    Jan 20, 2010
    Hesperia, Ca.
    Replace a turbo which cost me twice as much cause I didnt clean the air to air and blew the brand new one. I cleaned everything from the air cleaners(replaced the filters) and tubing on the cold side. Cost me 5k by the time I was done. I do most of my work BUT made a costly mistake. When they took the air to air apart once I was at the shop, there so much pieces in there and was told I was lucky nothing went into the intakes of the engine. I GAURANTEE that will NEVER happen again and I preach to others that they dont make the same mistake. I was in a hurry to get home, had worked 20 hours that day and had lost the turbo @ 3am. I was dead tired and wasn't thinking, and it cost me dearly.
  5. Cowpie1
    Cowpie1 Road Train Member
    5,569
    4,651
    Nov 25, 2008
    Kellogg, IA
    I have bypassed and air dryer that was not functioning properly. Used connectors, clamps, etc to splice broken air lines. Replaced engine belts. Replaced mudflaps and hangers. Done all sorts of wire splicing or replacing for lights. Caged brake chambers that were not working to release brakes. Replaced fuel filters in cold weather. Etc, etc, etc......
    heyns57 Thanks this.
  6. stranger
    stranger Road Train Member
    3,640
    4,959
    Oct 10, 2006
    NC
    I put a head, rocker box, and piston in the truck in my avitar, while sitting in the emergency lane on I-85, 30 miles north of Montgomery, Ala in 1976. Started about 10am and was rolling around 2am that night.
    Also put a turbo on in the emergency lane on I-40 in NC in the late 80's. Too many smaller things repaired on the road through the years to remember, like alternators in parking lots, u-joints, water pumps, ect.
  7. CondoCruiser
    CondoCruiser The Legend
    19,726
    18,734
    Apr 18, 2010
    Tennessee
    I fixed lights, mudflaps, changed fuel filters, swapped a starter, fixed an ECM wire broke into and changed a blower motor so I would have AC.
    Semi related, I had a friend break down 4 hours away in VA in his SUV. I drove up there, dropped his fuel tank and changed his fuel pump right in a convenience store parking lot. It was raining too. I did it because he had his kids with him and a repair like that on the road would of cost him an arm and a leg. Needless to say I was all nasty and tired when I got home around midnight. What a day. You don't want many like that.
  8. Injun
    Injun Road Train Member
    8,501
    9,491
    May 15, 2010
    West o' the Big Crick
    Well. I haven't made any of those big dramatic repairs.
    I carry a fairly basic tool kit: a 180-piece socket/wrench/screwdriver set, several sets of pliers, two Vise-Grips, A 4-pound hand sledge, a claw hammer, a wire tool, a crow bar and a side-cutter.
    I also carry a "trailer kit" that contains every light a trailer will need plus electrical connectors, shrink tubing and air line quick-connects. Of course, I carry every light my tractor could need, as well as fuses, extra coolant, oil and washer fluid.
    Disposable supplies are glad hand seals, zip ties, duct tape, black electrical tape, extra wiring, WD-40, and a motley collection of screws, nuts and bolts...with flat washers and lock washers.
    This gives you a fair idea of what I am prepared for.
    What I have done: replaced lights, rewired lights, fixed mud flaps, spliced a cracked air line and "repaired" a hole in the trailer with duct tape. Just the basics...enough to get me to a shop to have it done right.
    If that makes me less of a trucker, so be it. I'm not an expert and would rather trust the major stuff to people who know more about it than I do. Oh...and I'll take a trailer to a shop for top marker lights. I'm not tall enough to reach them, I don't carry a ladder, and I'm afraid of heights.
  9. WitchingHour
    WitchingHour Road Train Member
    3,424
    2,143
    Apr 1, 2011
    Broomfield, CO
    Replaced lights, glad hand seals, changed tires, repaired PTO units, replaced fuel filters, replaced air lines, replaced brake chamber boots, electrical system repairs, straightened out bend spreaders on dump beds... few other odds and ends.
  10. DirtyBob
    DirtyBob Road Train Member
    1,913
    1,628
    Sep 2, 2010
    Indiana
    The most I've had to do is replace the electrical line between the tractor and trailer when I was with my trainer. The electrical connection box on the trailer was going bad but I figured a new line would somewhat help since it was worn badly too. The old one wouldn't get a connection at all but the new one would as long as it was held up. I hooked a bungee up to the reefer frame and held the line up through the loop of it so the weight wouldn't pull the connector down. It worked pretty well although I would lose lights on the trailer in a sharp turn but only at the sharpest point of it for 1 second or so.
    The funny part was it took me a good 15 minutes to convince my trainer to let me do it. He kept insisting we take it to a TA the company told us to go to. It was out or route and we never would of made our next pickup before they closed. Fixed it in a few minutes for a much lower cost to the company and made our pickup before they closed. Not any kind of dramatic repair but it was pretty ridiculous to think about taking it to a shop for that.
  11. RAGE 18
    RAGE 18 Road Train Member
    1,529
    941
    Jan 31, 2011
    GOLD£N☆STAT£
    I adjust my brakes and change my trailer lights...thats it mechanics is not my thing I dont have the patience and I got big hands so squeezing them in to the engine try to get that last screw thats stuck rusted doesnt do me well.
