What type of semi is this referred to as?
Discussion in 'Questions From New Drivers' started by Bluebruce, Aug 25, 2014.
  1. Bluebruce
    Bluebruce Bobtail Member
    17
    4
    Jul 18, 2014
    Hey truckers I'm interested in driving a semi like this to start and get my foot in the door for a local distributing company, and I just want to know what these are referred to as. Also, what are the chances of getting hired driving one of those to start,with no experience other than driving school with a class a right out of driving school. Clean record,no felonies,healthy,and drug free of course.Obviously backing is pretty much like a regular vehicle, but what would training be like? Thanks everyone
  3. HeWhoMustNotBeNamed
    HeWhoMustNotBeNamed Crusty Pogosticker!!
    3,454
    19,721
    Jan 25, 2012
    Cartoon Network
    That's no Semi. That's a Straight Truck. "B" class CDL
    Tonythetruckerdude Thanks this.
  4. gokiddogo
    gokiddogo Road Train Member
    8,786
    14,769
    Mar 5, 2012
    Ontario Canada
    I'd call it a 10 wheeler ...
    sirstealth Thanks this.
  5. Bluebruce
    17
    4
    Jul 18, 2014
    Ah to be a rookie...:biggrin_2552: Thanks for the info!
    bullhaulerswife Thanks this.
  6. notsonewb
    notsonewb Light Load Member
    180
    78
    Jul 29, 2014
    That I think is a kenworth t300, it falls into the medium duty category , and most likely requires a class B if it has air brakes or if it is rated to gross 26,001 or more , if you put a Trlr behind it , you would most likely require an Class A , regardless of the brake type, if you go to driving school you will most likely get class A but thay may offer a class B only course and you would be gtg.go to your local BMV and pick up a copy of CDL study guide it covers all this and some I forgot to mention .hope this helps.
  7. Skunk_Truck_2590
    Skunk_Truck_2590 Road Train Member
    2,094
    684
    Feb 16, 2007
    Stonewall, LA.
    I call them a pain in the ### because they tend to get in the way entirely WAY to much and a good portion of the time impede traffic.
    kona911 and cabwrecker Thank this.
  8. MACK E-6
    49,502
    232,775
    If you are hauling beverages you WILL earn every cent you make. Believe that. Those guys work hard. I personally think LTL guys have it easier, since unlike the distributors they aren't hauling their own product.
  9. Chinatown
    Chinatown Road Train Member
    76,304
    176,126
    Aug 28, 2011
    Henderson, NV & Orient
    You won't have any problem finding a Class-B job driving something like that. Beverage companies, soft drink, beer, etc. always needing drivers. Hard on the back.
    cabwrecker Thanks this.
  10. double yellow
    5,946
    10,066
    Aug 28, 2011
    State of Jefferson
    "Semi" refers to the trailer -- as in semi-articulating trailer.
    That is a fancy way of saying a portion of the load is in front of the pivot point. On a typical 53' trailer, the kingpin (which is the pivot point) is 3' back from the front of the trailer. This is different from your typical ball & hitch automotive tow setup where the pivot point is at the ball -- in front of the load.
    The truck you posted is a "straight truck" or "box truck" & does not require a class A commercial license. It may not even require a class B (although with 3 axles it probably does). If you have a class A you could probably find a job without any additional training (at least driver training).
  11. browndawg
    browndawg Medium Load Member
    676
    1,213
    Dec 20, 2013
    Rock Island, IL
    I started out driving a straight truck, and then moved my way up to tractor trailers, no CDL school for me. Great way to start out, and Coke will probably hire you with no experience.
