What was wrong with the reset?
Discussion in 'Motor Carrier Questions - The Inside Scoop' started by chp56, Jun 4, 2013.
  1. chp56
    chp56 Light Load Member
    150
    33
    Sep 25, 2011
    Barstow, Ca
    That they had to change it?
  3. MNdriver
    MNdriver Road Train Member
    7,985
    4,372
    Feb 24, 2012
    too easy to use it more than once a week.
  4. ryan7892
    ryan7892 Light Load Member
    123
    45
    May 11, 2013
    Maryland
    The month of July is going to be a blast. They'll be checking logbooks like crazy.
    MNdriver Thanks this.
  5. BearGator56
    BearGator56 "The G stands for GOOD!"
    289
    53
    Apr 11, 2006
    Orlando, FL
    The bottom line is that not enough truck drivers are getting involved in the process and letting bureaucrats dictate your lives. Call your senators and congressmen. It's only going to get worse from here if we continue to let them stack rules on top of rules.
  6. RickG
    RickG Road Train Member
    12,812
    6,136
    Jul 22, 2008
    Owensboro , KY
    According to Joan Claybrook , former head of NHTSA under Jimmy Carter
    http://www.citizen.org/litigation/briefs/HealthSafety/autos/
  7. texan168
    texan168 Light Load Member
    50
    23
    Jun 18, 2012
    I have #####ed to anyone that would listen and a few that haven't. Unfortunately not knowing the political process and not able to afford a hired gun It's to no avail. I do have a question though I drive exclusivly at night. The reset requires two periods with 1 to 5 am off this is backwards for me. Is there anything that says it can be pm?
  8. Hardlyevr
    Hardlyevr Road Train Member
    3,270
    2,540
    Jul 30, 2009
    Mapleton Depot,PA
    The 2 periods of 1 AM to 5 AM makes sense if you are a daylight working driver. BUT if you are consistently a night worker or driver, it is the exact opposite of what your system wants/needs, and is actually bad for your circadian rhythm. Once again the Federal government is trying to ram a one rules fits all to the very diverse trucking industry.
    RockinChair Thanks this.
  9. KANSAS TRANSIT
    KANSAS TRANSIT Road Train Member
    4,080
    6,844
    Jul 28, 2011
    Glasco,Ks.
  10. Ridgeline
    22,385
    116,208
    I would agree with this but there is a problem thinking that not enough truck drivers are getting involved, we need more than just calling congress or joining the OOIDA.
    From my point of view the industry is fractured between company and non-company drivers with the company drivers split between union or union type work and non-union work. The non-company driver (small fleet and owner/operators) make up the majority who will be impacted by this rule change (limiting their load options and money) and are vocal to a point (OOIDA can do only so much) while the company drivers from the union or union type work won't be impacted anywhere near the level if at all so they won't get involved because there is no need to and the company non-union drivers will have to deal with it because they are controlled by the company directly and have no choice hence don't care to get involved.
    It is sad to run into a company driver who refuses to contact their congressional representive or even vote while complaining about the conditions they have to drive under not realizing they are the reason why they have to put up with this.
    driverdriver Thanks this.
  11. Richter
    Richter Road Train Member
    4,090
    1,700
    Feb 13, 2012
    Philadelphia Pa
    So a few drivers fall asleep at the wheel and they punish all of us. What happened to personal responsibility. If I'm tired I pull over regardless of what my qualcome tells me. I say get rid of hours of service, but If you fall a sleep at the wheel and hit somthing you should loose your CDL for a month. Then people would self govern their hours a lot better because they don't want to loose their job for a month. Repeat offenders 6 months or a year.
